Hallo bekomme das mit Aida64 nicht hin kan nicht so gut Englisch werd nicht schlau aus der Anleitung hier:
guess that only means the Mass Storage Mode of the DPF. Once AIDA64 switches the device to Mini Monitor Mode (as required for LCD support), Windows 8.1 will not find the necessary drivers.
We've done a few test runs with Windows 8.1 64-bit and a SPF-75H DPF. The good news is: it works. Bad news is: only the driver works, the Samsung Frame Manager application goes nuts under Windows 8.1. It means you won't be able to use the DPF as a mini monitor (to extend your desktop to the DPF), but you can use it as a LCD device with AIDA64. What needs to be done to make it working:
1) Install Samsung Frame Manager for Vista 64-bit v2.00. During its installation process a lot of popup windows will come up, don't worry about them, just close them all.
2) Start AIDA64, enable Samsung SPF LCD support in AIDA64 / main menu / File / Preferences / Hardware Monitoring / LCD. It will switch the device from Mass Storage Mode into Mini Monitor Mode. After the transition AIDA64 will report that it cannot open the LCD. Don't worry about it, just close AIDA64.
3) Go to Device Manager, and install the device driver for the unknown device called Samsung Digital Photo Frame. You can find the driver in the \Program Files\Samsung\FrameManager folder. If it's necessary, select the INF file called sam_miniusb.inf.
4) You can uninstall Frame Manager after the driver is successfully installed.
I've checked, and the mentioned Frame Manager for Vista 64-bit v2.00 does support SPF-83H DPF that you're about to get.
Kan mir jemand ungefähr sagen wie ich das anstellen soll mit meinem Englisch bin ich schnell am Ende.
