Microsoft (R) Windows Debugger Version 6.12.0002.633 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\Minidump\Mini081110-15.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 2600.xpsp_sp3_gdr.100216-1514
Machine Name:
Kernel base = 0x804d7000 PsLoadedModuleList = 0x805634c0
Debug session time: Wed Aug 11 17:20:11.609 2010 (UTC + 2:00)
System Uptime: 0 days 0:00:40.296
Loading Kernel Symbols
.!analyze –v
Loading User Symbols
Loading unloaded module list
Unable to load image RtkHDAud.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for RtkHDAud.sys
*** ERROR: Module load completed but symbols could not be loaded for RtkHDAud.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000000A, {1, 1c, 1, 804e1c18}
Probably caused by : RtkHDAud.sys ( RtkHDAud+41813d )
Followup: MachineOwner
1: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00000001, memory referenced
Arg2: 0000001c, IRQL
Arg3: 00000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: 804e1c18, address which referenced memory
Debugging Details:
WORKER_ROUTINE:
+2902faf00acdfc0
00000001 ?? ???
WORK_ITEM: 804e1c18
CURRENT_IRQL: 1c
CUSTOMER_CRASH_COUNT: 15
DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
BUGCHECK_STR: 0xA
PROCESS_NAME: Skype.exe
LAST_CONTROL_TRANSFER: from f273813d to 804e1c18
STACK_TEXT:
b7c2c368 f273813d 00000000 00000000 00000000 nt!KeWaitForSingleObject+0x186
WARNING: Stack unwind information not available. Following frames may be wrong.
b7c2c394 f272e8cc 852352ac 804d9bcf 00000000 RtkHDAud+0x41813d
b7c2c3f0 f272f251 8509d960 8509d968 c0000001 RtkHDAud+0x40e8cc
b7c2c40c f2750a95 860640b0 00000002 00000000 RtkHDAud+0x40f251
b7c2c438 f231a049 860a1cd0 8522cefc 00000000 RtkHDAud+0x430a95
b7c2c470 f2318df2 00000000 8604f560 8626a928 portcls!CPortPinWaveCyclic::Init+0x250
b7c2c498 f230cfe3 8604f520 8605bdc4 8605bdc8 portcls!CPortFilterWaveCyclic::NewIrpTarget+0xd9
b7c2c4e0 f230d132 8626a928 85f4c920 84fe7e70 portcls!xDispatchCreate+0x90
b7c2c4f4 f65c5fdb 85f4c920 84fe7e70 84fe7e80 portcls!KsoDispatchCreateWithGenericFactory+0x2b
b7c2c518 f65c50c6 85f4c920 00000000 b7c2c540 ks!DispatchCreate+0xc7
b7c2c528 f230d09d 85f4c920 84fe7e70 85f26f38 ks!KsDispatchIrp+0x98
b7c2c540 804e13eb 85f4c920 84fe7e70 84fe7e70 portcls!DispatchCreate+0x34
b7c2c550 805794b6 860a5838 84efec58 b7c2c720 nt!IopfCallDriver+0x31
b7c2c630 80583063 85f4c920 00000000 84fb5008 nt!IopParseDevice+0xa12
b7c2c668 80572bd5 860a5838 00000000 84fb5008 nt!IopParseFile+0x46
b7c2c6e0 805701e7 800010f0 b7c2c720 00000240 nt!ObpLookupObjectName+0x119
b7c2c734 80579b12 00000000 00000000 fb79f800 nt!ObOpenObjectByName+0xea
b7c2c7b0 80579be1 e2c8bc70 40000000 b7c2c858 nt!IopCreateFile+0x407
b7c2c80c f65c64ee e2c8bc70 40000000 b7c2c858 nt!IoCreateFile+0x8e
b7c2c888 f65c5a77 800010f0 f65c5a80 e2dff0e0 ks!KsiCreateObjectType+0xd6
b7c2c8a8 b83d0fdf 800010f0 e2dff0e0 40000200 ks!KsCreatePin+0x33
b7c2c8cc b83d16fc e101d210 e2c0fca8 e2792328 sysaudio!CPinNodeInstance::Create+0x6b
b7c2c908 b83d0454 84f8b1b8 e101d20c 00000001 sysaudio!CConnectNodeInstance::Connect+0xb3
b7c2c924 b83d8851 00000000 84f8b138 84f8b1b8 sysaudio!CStartNodeInstance::Connect+0x52
b7c2c95c b83d6dd4 e1b81c48 84f8b138 84f8b1b8 sysaudio!CStartNodeInstance::IntelligentConnect+0x79
b7c2c980 b83cf574 e2de6e10 e2a71298 84f8b138 sysaudio!CStartNodeInstance::Create+0xe1
b7c2c9b0 b83d01e7 c0000010 84f8b138 00000000 sysaudio!CPinInstance::PinDispatchCreateKP+0xa8
b7c2c9cc b83cf718 84fb8490 b83cf4e6 84f8b138 sysaudio!CInstance::DispatchCreate+0x63
b7c2ca00 f65c5fdb 84f52498 84fb8490 84fb84a0 sysaudio!CPinInstance::PinDispatchCreate+0xc1
b7c2ca24 804e13eb 84f52498 00000000 84fb8490 ks!DispatchCreate+0xc7
b7c2ca34 805794b6 860a5bd8 85021248 b7c2cc04 nt!IopfCallDriver+0x31
b7c2cb14 80583063 84f52498 00000000 85fabf30 nt!IopParseDevice+0xa12
b7c2cb4c 80572bd5 860a5bd8 00000000 85fabf30 nt!IopParseFile+0x46
b7c2cbc4 805701e7 00000760 b7c2cc04 00000040 nt!ObpLookupObjectName+0x119
b7c2cc18 80579b12 00000000 00000000 00000001 nt!ObOpenObjectByName+0xea
b7c2cc94 80579be1 0364ea94 80000000 0364ea10 nt!IopCreateFile+0x407
b7c2ccf0 80573e2b 0364ea94 80000000 0364ea10 nt!IoCreateFile+0x8e
b7c2cd30 804dd99f 0364ea94 80000000 0364ea10 nt!NtCreateFile+0x30
b7c2cd30 7c91e514 0364ea94 80000000 0364ea10 nt!KiFastCallEntry+0xfc
0364ea3c 00000000 00000000 00000000 00000000 0x7c91e514
STACK_COMMAND: kb
FOLLOWUP_IP:
RtkHDAud+41813d
f273813d ?? ???
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: RtkHDAud+41813d
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: RtkHDAud
IMAGE_NAME: RtkHDAud.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 44cf35d2
FAILURE_BUCKET_ID: 0xA_RtkHDAud+41813d
