Naja, das klaut doch nur FPS ? Und bringt doch rein gar nix oder ?
Könnt ihr mir sagen welche Einstellung am besten für mich wären ?
Also Vsync an aus ?
AA/AF ?
usw.
PC Patch: 1.02 an issue was found during testing. A new patch has been built and is going through the first stages of submission with Microsoft. This will result in a small delay in the patch schedule.
Daten:AMD Athlon 64 X2 Dual Core 6400+, 0,NVIDIA GeForce 9400 GT 1024.0 MB, Mainbord: Speicher: 2047.3 MB
- Resolved an issue which could prevent the user successfully saving with profiles that contained unicode characters.
- UI elements are no longer incorrectly displayed in Gymkhana
- Improvements to input system, supporting multi-device action maps. The user can now set button configurations to span multiple devices; previously a bug would cause these settings to be lost upon game restart.
- Corrected various spelling mistakes across all languages
- Reset line corrections to prevent potential ‘out of world’ or ‘driving into crowd’ issues on several tracks
- Corrected an issue which could, in rare circumstances, prevent the display from rendering in the event of 16xCSAA being selected.
- Steering wheel no longer jolts to the left in the race reward screen
- Removed an incorrect limitation which could cause VSync to lock the refresh rate to 60Hz on a 120Hz system.
- Physics output to motion simulators is now correctly faded out at the end of a race, preventing some situations within which motion would continue after crossing the finish line.
- Adjusted head camera configuration to avoid excessive vibration effects when VSync is disabled.
- Front end menu improvements for multi-display systems, correcting a small number of visibility issues.
- Improvements to GPU detection, correcting a potential issue which in some circumstances could prevent SLI scaling operating correctly with DirectX 11.
- Implemented native stereoscopic support for compatible devices.
- Inclusion of a benchmarking utility, simplifying the process of gathering performance statistics.
- Various stability fixes.
Hätte nicht gedacht das ich das Spiel mit mein Sys auf 1920x1080 mit 40-70fps auf Maxedout pack sprich Hoch - Sehr hoch ^^
