Clawhammer
PCGH-Community-Veteran(in)
Teamspeak 3.0.0-rc2 verfügbar
Seit dem gestrigen Tag wird automatisch bei denen die, die Update.ini im Installationsordner haben, der Teamspeak Client auf die Version 3.0.0-rc2 geupdatet.
Wer diese Update.ini noch nicht im Installationsordner vom Teamspeak hatte kann sie gerne vom Anhang herrunterladen und hinzufügen, eine Anleitung ist enthalten.
Originale Patchnotes:
Diese sind auch im Teamspeak unter: "Hilfe" -> "Changelog lesen" erhältlich.
- Clawhammer -
Code:
TeamSpeak 3 - Client Changelog
Copyright TeamSpeak Systems GmbH
http://www.teamspeak.com
+ Added feature or noticable improvement
- Bug fix or something removed
* Changed or Information
! Important - Take note!
=== Client Release 3.0.0-rc2 02 Jun 2011
+ Added banner resize mode to virtualserver settings.
+ Channel context menu "unsubscribe from channel family" is available as soon
as any subchannel is subscribed.
+ "Set Avatar" now is disabled without permission.
+ Added package installer for easy plugins/styles/soundpacks etc. one-click
installations.
* Plugin authors note: requestChannelSubscribe and requestChannelUnsubscribe
now take an array of channelIDs as parameter instead of a single channelID.
* Exchanged default soundpack with male and female soundpacks.
* Added soundpack page to setup wizard to select one of male or female.
* Select and scroll to own client after connecting.
* Fixed switching a fullscreen game to desktop when client is minimized and
showing the "warn while muted", the "entering moderated channel", the
"force push-to-talk" or the "maximum amount of clients reached" dialog.
* Client and server log windows now save and restore log level checkbox states.
* Added "Debug" checkbox to control debug output in client log window.
* Added "Delete" to channel permission to set i_channel_needed_delete_power.
- Support for international domain names readded.
- Removed validation of input text from connection connect and bookmark
address field, so that every address can be used.
- Fixed possible crash in AppScanner plugin with Umlauts.
- Added a missing separator within an invitation.
- Moved rest of the sounds into soundpack for more customized handling.
- Fixed that poke dialog no longer opens when nickname was changed.
- Changed the Push-To-Talk tooltip lines which were displayed in wrong order.
- Fixed displaying port when connected via invitation.
- Fixed errordisplay when family subscriptions on channels fail.
- Fixed dropping images from filebrowser into channel description when
connected on multiple servers.
- Fixed context menu to copy offlinemessage text.
- Limited the last mentioned URLs in systemtray context menu to 10.
- Fixed that image-descriptions near avatar are sometimes written over the edge
- Image in channel description was broken when overwritten with same name.
- Fixed that offline messages throws a warning when recipient wasn't found on
the server.
- Don't save empty subscribed channels list when quickly disconnecting again
from a server, loosing the subscribed channels.
- Fixed problem when binding hotkeys while joysticks were active that "pressed"
a button constantly.
- Fixed that TeamSpeak does not start as a result of broken input device
drivers. If detected TeamSpeak will at least start without usable hotkeys.
- Fixed ts3server:// links being overwritten by autoconnect bookmarks when a
bookmark for the linked server already exists.
- Clawhammer -
