Pillemann5000
Eigentlich sollte der Patch am 12.Mai kommen, wurde aber gestern auf heute vorverlegt.
Der Patch wird folgendes beinhalten:
Changes
- Fix for CO2 not being saved correctly
-Fix for crew morale
- Fix for weather being reset to clear weather after load
- Fixes for crewmen showing under water under certain conditions
- Fixes for ships exploding in ports or hitting the shore
- Now plot course tool is no longer accessible in the bunker
- Several fixes to ship recognition manual
- Man the deck gun / flak gun orders doesn’t cost morale anymore
- No more crewmembers on burning ships
- Several crew animation and interaction fixes
- Fixed some performance problems inside submarine
- Fixed selection contour being visible when a character was already selected
- Fixed a bug where the moon was closer than it should
- Fixed a bug where the sun disk would be visible underneath thick cloud cover
- Fixed torpedo doors
- Fixed torpedo propeller not turning
- Fixed electric torpedoes trail
- Fixed several dials that were not working inside the submarine
- Fixed a bug where the player can get stuck in the sub's outer hatch geometry
- Fixed a problem with magnetic detonators didn't work properly
- Fixed several localization problems on the German version
Quelle: Neue Informationen zum Patch 1.2 - Thema entwickelt von eve community
Changes
