Samsung LS27C350H
Lokimilestone
Hallo zusammen ich habe mir einen neuen Monitor gekauft und will nun die Auflösung auf HD stellen 1920x1080 aber irgendwie kann der Monitor das nicht darstellen es bleibt rund um das BIld ein schwarzer Rand siehe Foto
http://s1.directupload.net/images/140108/4rua69vx.jpg
Hier meine Systeminfos:
System Information
Time of this report: 1/8/2014, 17:53:50
Machine name: LOKI-PC
Operating System: Windows 7 Professional 64-bit
Language: German (Regional Setting: German)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: X38-DQ6
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 6144MB RAM
Available OS Memory: 6142MB RAM
Page File: 2743MB used, 9540MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: AMD Radeon R9 290 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x67B1)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_67B1&SUBSYS_E285174B&REV_00
Display Memory: 4095 MB
Dedicated Memory: 3072 MB
Shared Memory: 1023 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: PnP-Monitor (Standard)
Monitor Model: S27C350
Monitor Id: SAM0A3E
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1247 (English)
Driver Version: 13.250.18.0
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 10/8/2013 05:34:44, 1312896 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71EE2-24F1-11CF-2470-8FC2BEC2C535}
Vendor ID: 0x1002
Device ID: 0x67B1
SubSys ID: 0xE285174B
Revision ID: 0x0000
Driver Strong Name: oem101.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_NewZealand:13.250.18.0:pci\ven_1002&dev_67b1
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{A491560E-FFE4-4202-9B1D-2DCD004EB9E3}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Wäre super wenn mir jemand helfen könnte.
Normal bei AMD Karten, geh mal in die Treibereinstellungen und da auf Overscan.
Da dann den Wert so verändern bis der Rand weg ist.
Ein Freund von mir hat sich den Monitor die Tage auch gekauft und hat folgendes Problem (Angeschlossen ist er über HDMI, aber auch Analog hab ich ausprobiert, da kein DVI Anschluss vorhanden ist.) :
Wenn wir ein Video bei Youtube oder woanders anmachen, kommen ab und zu so Bildfehler. In der Mitte des Monitors ziehen sich horizontale Streifen durch das Bild, welche wenige ms andauern. Nur bei genauerem betrachten sind diese erkennbar. Ist der Monitor defekt?
Können Nachladeruckler sein oder es liegt am Kabel.
Kenne sowas nur von Watchever, wenn das Kabel da kein DHCP unterstützt hast du teilweise Bildaussetzer.
Sind die Probleme denn auch da, wenn ihr nen Spiel am laufen habt?
Wohl nicht mehr ganz aktuell - aber vielleicht spricht es Besitzer des Monitors hier im Forum an:
Ich habe diesen Monitor gerade als Zweitmonitor gekauft. Leider komme ich mit den Bildeinstellungen (Helligkeit, Kontrast, Farbe) überhaupt nicht klar und bin mit dem Bild einfach nicht zufrieden, da einfach die Farbsättigung fehlt.
Die Farben gefallen mir nur im MagicBright Cinema Modus gut. Leider ist die Schärfe hier viel zu hoch und man sieht die Konturen sehr stark.
Können Besitzer dieses Monitors bitte mal ihre Bildeinstellungen posten? Vielen Dank im Voraus!
Pushen ist nicht gern gesehen, vor allem wenn man nen fremden Thread entert für ein anderes Problem.
