Metro Exodus - crash question. 2080 Ti Aorus Xtreme and 9900K
dr222
Hello. I had a crash in VOLGA level after sneaking a bandit train when going to main base.
Game frozed, screen frez and "A crash has been detected by BugTrap".
CTRL ALT DELETE -> logout and its fine again.
Event viewer said: nothing info. Not display recovey crash, not TDR.
Only:"The description for Event ID 1 from source SMBCtrl cannot be found." Its from RGB fusion but i dont think its related. And "Event , LedLib2"
Just simply crash. It happened today,before was fine.
I can play 24 hours stable but today it happened after 3 minutes after starting game.
All my pc:
9900K 5ghz 65C on game
32GB DDR4 GSKILL 3000MHZ
Corsair 850RmX
2080 Ti Aorus Xtreme ( no oc ,stock )
Asus Prime Z390-A
The newest nvidia drivers currently have
Is this related to game or hardware?
In other games,and benchmarks not single crash
The level volga has several bugs, please install the last patch. The current build is 1.0.1.3.
I wonder why you're dialed in into the "crash" thingy so much? Your posts usually circling around "game xyz crashes - related to oc / oven / neighbours cat making obscene poses at the window?". Have some faith in your PC, although it's just an intel (secretly inducing pcmasterraceamdintelnvidiabash) :devil: , but ... hhcchkkrkrrkrsssssssshhhhttrrmmppp
[A problem has been detected and Meddldüp has been shut down to prevent sanity to your topic.]
[collecting data for trash dump .... 0%]
Your posts usually circling around "game xyz crashes...
Because you can read this in the patch nodes of the game developer. The rest is incomprehensible to me, whatever they want to express.
A hardware defect can be excluded. That the game makes problems in certain levels is known and correct. The questions are then allowed.
