Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*C:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`03013000 PsLoadedModuleList = 0xfffff800`03258670
Debug session time: Sat Aug 27 03:09:41.802 2011 (UTC + 2:00)
System Uptime: 0 days 0:03:32.332
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 00000000`7efdf018). Type ".hh dbgerr001" for details
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa8007ca5028, b201a000, 175}
Probably caused by : hardware
Followup: MachineOwner
2: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8007ca5028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b201a000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000175, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_AuthenticAMD
[COLOR=black]DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: prime95.exe
CURRENT_IRQL: f
STACK_TEXT:
fffff880`0316ca88 fffff800`0360ea3b : 00000000`00000124 00000000`00000000 fffffa80`07ca5028 00000000`b201a000 : nt!KeBugCheckEx
fffff880`0316ca90 fffff800`031a0513 : 00000000`00000001 fffffa80`07ca6ea0 00000000`00000000 fffffa80`07ca6ef0 : hal!HalBugCheckSystem+0x1e3
fffff880`0316cad0 fffff800`0360e700 : 00000000`00000728 fffffa80`07ca6ea0 fffff880`0316ce30 00000000`0421da00 : nt!WheaReportHwError+0x263
fffff880`0316cb30 fffff800`0360e052 : fffffa80`07ca6ea0 fffff880`0316ce30 fffffa80`07ca6ea0 00000000`00000000 : hal!HalpMcaReportError+0x4c
fffff880`0316cc80 fffff800`03601e8f : 00000000`04229780 00000000`00000001 fffff880`0316ceb0 00000000`00000000 : hal!HalpMceHandler+0x9e
fffff880`0316ccc0 fffff800`0308e52c : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x47
fffff880`0316ccf0 fffff800`0308e393 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x6c
fffff880`0316ce30 00000000`00551ea8 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x153
00000000`02344100 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x551ea8
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_CACHE
