MACHINE_CHECK_EXCEPTION?
Knogle
Volt-Modder(in)
Hallo liebe Community ,
Ich bekomme mit meinem PC nun seit einiger Zeit wieder Bluescreens mit dem Inhalt MACHINE_CHECK_EXCEPTION , jedoch tauchen nur aeltere im Dump Ordner auf
Die Bluescreens treten manchmal beim packen von Megaordnern auf die dann Fehler aufweisen oder beim Start
Was bedeutet dieses machine check exception?
Bitte um Hilfe!
Das kann ein Hardwarefehler, hervorgerufen durch alles mögliche sein:
A machine check exception occurs when Windows and your hardware platform cannot recover from a hardware error so that the system can continue to run successfully and reliably. More specific diagnosis of machine check exceptions is difficult, and there is no general solution. Contact your hardware manufacturer or a computer hardware technician for help with troubleshooting this issue.
Machine check exceptions are frequently caused by one of the following conditions:
a) You are running the processor or main board beyond its specifications. For example, you are over- clocking the processor or bus. We recommend that you run your hardware at the manufacturer-rated speeds.
b) Noisy power, overstressed power strips, outmatched power supplies and failing power supplies can destabilize your computer. Make sure that you have a stable, reliable power supply to your computer.
c) Extreme thermal conditions caused by the failure of cooling devices such as fans may damage your computer. Make sure that your cooling devices are all working.
d) You have damaged memory or memory that is not the correct type for your computer. If you recently changed the memory configuration, revert to the previous configuration to determine what is wrong. Make sure that you are using the correct memory for your Computer
machine check exception - windows 8 - Microsoft Community
Sind alles Treiber aktuell, hast Du übertaktet und welche HW kommt zum Einsatz?
Treiber aktuell bzw. so aktuell wie es geht (stand 2009 gibt nix neueres)
Habe auf 3,4Ghz uebertaktet und ich habe ein P6X58D-E und einen Xeon X5650
Einige Zeit vorher war der Xeon noch auf 3,8Ghz uebertaktet , wurde aber nie ueber 1,27V betrieben
Habe 3x 4GB RAM Riegel von Gigabyte
Versuche es doch mal ohne übertrakten und teste mal die Ram-Riegel einzeln durch. Welches Netzteil hast Du?
Ein paar CPU Pins sind verbogen , jedoch kriege ich die nicht ganz gerade deshalb funktionieren nur die Baenke A1 A2 und A3 alle mit B nicht
Dann liegt es daran. Hatte ich auch mal bei einem Board, da wurden wegen zweier verbogener Pins jede Menge ECC Fehler geworfen.
Macht ein Uhrmacher sowas denn?
Mich wundert halt nur das die Probleme jetzt erst auftauchen nach einigen Monaten Betrieb
/e: ram wurde jeder einzeln getestet und einmal alle 3 , keine Fehler
