G.Skill Trident Z 16GB, 3600, CL15-15-15-35 @ 3733, CL14-14-14-28
  • Ersteller Ersteller RNG_AGESA
  • Erstellt am Erstellt am
R
RNG_AGESA
Guest
G.Skill Trident Z silber/rot DIMM Kit 16GB, DDR4-3600, CL15-15-15-35 (F4-3600C15D-16GTZ
G.Skill Trident Z silber/rot DIMM Kit 16GB, DDR4-3600, CL15-15-15-35 ab €'*'176,64 (2019) | Preisvergleich Geizhals Deutschland
some results of korean OC guys down below + pretty nice working settings @ 3800 CL 16 @ 1.38V
@3200 12-11-11-11-22
@3466 13-12-12-12-24
@3600 14-13-13-13-26
@3733 14-14-14-14-28
@3800 16-15-15-15-30 best score, 24/7 stable @ 1.1 SoC V
@3800 16-16-17-16-32 stable
Coole Ergebnisse. :Daumen:
Edit
Könntest du vielleicht einmal cinebench durchlaufen lassen mit Standardwert und mit den 3733CL14? Wäre echt super.
Gesendet von meinem HTC mit Tapatalk
edit: wrong profile
schoene Werte! Leider waren keine Trident Z's verfuegbar als ich bestellte... so wurden es leider "nur" Flare X 3200 cl 14. Hatte mal geschaut ob mit 1.4-1.45volt vllt 3600 cl14 drin sind , leider nein :(.
Also Glueckwunsch zu dem Kit :-)!
Hi RNG_AGESA
Can you try higher frequencies without IF 1: 1? Basically I want to know if they are any better than 3200 C14 and 3600 C16. They are supposed to be one of the best B-Die bins.
I have:
F4-3200C14D-16GVR
F4-3600C16D-16GVK
And they do this on 10600K and MSI Z490 TOMAHAWK:
3200 C14 ~1.30V
3333 C12 ~1.50V
3600 C16 ~1.30V
3600 C15 ~1.35V
3600 C14 ~1.35V
3600 C13 ~1.48V
3900 C15 ~1.45V
3900 C14 ~1.50V
4000 C16 ~1.40V
4000 C15 ~1.50V
4100 C15 ~1.52V
4133 C15 ~1.55V
4200 C16 ~1.45V
4266 C16 ~1.50V
This is just primary timings, tRCD and tRP same as tCL.
I run Prime95 Large for 40 minutes and give + 0.02V in case of error / BSOD or + 0.01V in case they work.
I reckon F4-3600C15D-16GTZ should do better at least on 3600 C15, around 1.30V. But what I wonder is if they need -0.05V across the frequency / CL range, or are they similar.
Because 3200 CL14 is exactly the same as 3600 CL16, except for 3600 CL16 where it needs + 0.06V. But it's same on 3600 CL15 and CL14. Maybe just a coincidence, but it also makes sense, as 3200 CL14 are not tested on 3600 CL16 and so can require more than 1.30V. 3600 CL16 on other hand must be tested on 3600 CL16 and I would say they must pass at max 1.30V.
If you don't have much will or time, can you please just test lowest voltage on:
3600 C15
3600 C13
3900 C14
4000 C15
I think these should provide enough info for me.
Some say + 0.05V doesn't really matter for B-Die. But I don't see anything else separating these bins.
