stolle80
PCGHX-HWbot-Member (m/w)
Crysis 3 bekommt einen neuen Patch .
Der Patch 1.4 hat auch Änderungen für den Singleplayer.
Er kommt sowohl für den PC, die Xbox360 und die PS3.
Ein Auszug aus den Änderungen:
Multiplatform
Multiplatform
- XP Bonus module now applies to kill assists
- Issues with Rip & Throw items getting out of sync between client and server fixed
- All after match awards count towards getting dog tags, not just the three displayed on the progression screen
- Support bonuses on Brooklyn Bridge changed
- Support bonuses on Hell's Kitchen changed
- Retriever rank 3 now displays the correct Max Suit timer on the HUD
- Fix for tagging icon incorrectly displaying after player respawn
- Trying to zoom to second stage during iron sight no longer melees and breaks you out of zoom
- Fix for win/loss stats in Hunter game mode
- Fix for Maximum Suit moving slower than intended when activated when in Armour mode
- Explosive damage to targets now provides assist points when they are killed
- Brought "Survival Instinct" skill assessment in line with the UI text
- Fix for Surveillance failing to prevent the user being tagged when at rank 3
- Fix for reduced recoil when tapping fire
- Fix for team switching in Assault resulting in having the wrong loadout for the side you are on
- Fix for Expanded Arsenal module giving 3 additional JAW rockets instead of 1
- Reduced caching of player profiles in the lobby so player stats are more up to date
- Ripped off HMGs now have consistent accuracy when ADS
- Fixes for some Max Suit issues when triggered just as the player is dying
- Iron sight sensitivity override fix
- Added ability to disable HMGs and auto unlock attachments on unranked servers
- Transition from ranked prematch to unranked ingame now respawns players correctly
- Fixed issues with Ping attack not rebinding when Melee is Rebound
