Tagebuch Changelog + Roadmap and Download
Status
NV-UV v0.99 released (Build 22 Cantor)
The community update: UV⚡Try learns community ratings and accepts your own settings, NV-UV notifies you about new versions, and a round of fixes based on tester reports.
New features
  • Community ratings: A star click in UV⚡Try stores your personal note locally and counts as an anonymous community vote at the same time. The new Community column shows the average of all votes with the vote count, updated twice a day.
  • Share your settings: Right-click a filled profile slot to submit its UV values to the community database. Submissions go through a short review and then appear for everyone, labeled user-submitted.
  • Update notifier: NV-UV now shows an in-app hint when a new version has been released. The check is a pure read-only download from GitHub, nothing is transmitted.
  • Memory footprint: When minimized to the tray, NV-UV hands its working set back to Windows and shows up noticeably lighter in Task Manager.
  • Game Replay: The frequency step now goes down to 15 MHz, matching the hardware-native V/F granularity.
  • Recalibrate: Right-click on the Recalibrate button opens the folder with the automatic Afterburner profile backups.
Under the hood
  • .NET 10: All projects migrated to the current runtime.
  • GameDatabase v2.12: 640 games.
Fixes
  • UV-Pilot: A fast game exit and restart could skip the slot backup and later reset the anchor slot to stock. Fixed, plus a safety net: the active anchor slot never silently falls back to stock anymore.
  • Recalibrate: Custom Afterburner install locations (for example Winget installs) could get lost during the Recalibrate restart. The detected path is now persisted and Winget locations are scanned.
  • Game detection: Crash reporter helper processes (BugSplat, Unreal, Unity, Windows Error Reporting) are no longer mistaken for games.
Docs
  • Russian Tester Guide: A community-contributed full translation now ships with every build, next to the German and English guides.
  • Privacy: New section in all three guides plus a PRIVACY.md in the docs repo describing exactly what the community features transmit and what never leaves your machine.
This is the last Cantor release apart from hotfixes. The next version will be v1.00 "Kaluza" with a few surprises.
Download: https://github.com/christianp403-spec/NV-UV/releases/latest
VG Christian
NV-UV v0.99 veröffentlicht (Build 22 Cantor)
Das Community-Update: UV⚡Try lernt Community-Bewertungen und nimmt eigene Settings entgegen, NV-UV meldet neue Versionen selbst, dazu eine Runde Fixes auf Basis eurer Tester-Reports.
Neue Features
  • Community-Bewertungen: Ein Sterne-Klick in UV⚡Try speichert die persönliche Notiz lokal und zählt gleichzeitig als anonymer Community-Vote. Die neue Community-Spalte zeigt den Durchschnitt aller Votes samt Anzahl, aktualisiert zweimal täglich.
  • Eigene Settings teilen: Rechtsklick auf einen belegten Profil-Slot reicht dessen UV-Werte in die Community-Datenbank ein. Einreichungen durchlaufen eine kurze Prüfung und erscheinen danach für alle, gekennzeichnet als user-submitted.
  • Update-Hinweis: NV-UV zeigt ab jetzt in der App an, wenn eine neue Version erschienen ist. Der Check ist ein reiner Lese-Download von GitHub, es wird nichts gesendet.
  • Speicherverbrauch: Ins Tray minimiert gibt NV-UV den Arbeitsspeicher an Windows zurück und taucht im Task-Manager deutlich schlanker auf.
  • Game Replay: Der Frequenz-Schritt geht jetzt bis 15 MHz hinunter und trifft damit das hardware-native V/F-Raster.
  • Recalibrate: Rechtsklick auf den Recalibrate-Button öffnet den Ordner mit den automatischen Afterburner-Profil-Sicherungen.
Unter der Haube
  • .NET 10: Alle Projekte auf die aktuelle Runtime migriert.
  • GameDatabase v2.12: 640 Spiele.
Fixes
  • UV-Pilot: Ein schnelles Beenden und Neustarten eines Spiels konnte das Slot-Backup überspringen und später den Anker-Slot auf Stock zurücksetzen. Behoben, zusätzlich mit Sicherheitsnetz: Der aktive Anker-Slot fällt nie mehr stillschweigend auf Stock zurück.
  • Recalibrate: Benutzerdefinierte Afterburner-Installationspfade (zum Beispiel Winget-Installationen) konnten beim Recalibrate-Neustart verloren gehen. Der erkannte Pfad wird jetzt persistiert, Winget-Pfade werden gescannt.
  • Spielerkennung: Crash-Reporter-Prozesse (BugSplat, Unreal, Unity, Windows Error Reporting) werden nicht mehr fälschlich als Spiel erkannt.
Doku
  • Russischer Tester Guide: Eine vollständige Community-Übersetzung liegt ab jetzt jedem Build bei, neben dem deutschen und englischen Guide.
  • Privacy: Neue Sektion in allen drei Guides plus eine PRIVACY.md im Docs-Repo, die genau beschreibt, was die Community-Features übertragen und was den Rechner nie verlässt.
Das ist die letzte Cantor-Version abgesehen von Hotfixen. Die nächste Version wird v1.00 "Kaluza" mit ein paar Überraschungen.
VG Christian
Status
