brauche dringend euere Hilfe!
Mein Rechner:
CPU: Core i7-2600k @ 3,40GHZ
Mobo: ASUS P8P67 Bios 1305
RAM Corsai Vengeance 6GB 1600MHZ CL 8 @ 1.5Volt
Grafikkarte: Gainward GS GTX 560 Ti Treiber 166.66
Netzteil: Coba 750Watt
Bs: Win 7 x64 Home Premium
...stürzt unterschiedlich ab, mit folgenden Bsod
- System
- Provider
[ Name] Microsoft-Windows-WER-SystemErrorReporting
[ Guid] {ABCE23E7-DE45-4366-8631-84FA6C525952}
[ EventSourceName] BugCheck
- EventID 1001
[ Qualifiers] 16384
Version 0
Level 2
Task 0
Opcode 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2011-03-11T09:39:51.000000000Z
EventRecordID 19025
Correlation
- Execution
[ ProcessID] 0
[ ThreadID] 0
Channel System
Computer Jürgen-PC
Security
- EventData
param1 0x0000001e (0x0000000000000000, 0x0000000000000000, 0x0000000000000000, 0x0000000000000000)
param2 C:\Windows\MEMORY.DMP
param3
hier den auszug der Dump:
16.1: kd:x86> !analyze -v
* Bugcheck Analysis *
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: 0000000000000000, The exception code that was not handled
Arg2: 0000000000000000, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: 0000000000000000, Parameter 1 of the exception
Debugging Details:
EXCEPTION_CODE: (Win32) 0 (0) - Der Vorgang wurde erfolgreich beendet.
FAULTING_IP:
+0
00000000 ?? ???
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 0000000000000000
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x1E
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 0000000000000000 to 0000000000000000
STACK_TEXT:
00000000 00000000 00000000 00000000 00000000 0x0
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: INVALID_KERNEL_CONTEXT
Followup: MachineOwner
Arguments:
Debugging Details:
FAULTING_IP:
+0
00000000 ?? ???
BUGCHECK_STR: 0x1E
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
Ich bedanke mich schon mal im Vorraus für euer Hilfe!
Gruss V200
Mein Rechner:
- System
- Provider
- EventID 1001
[ Qualifiers] 16384
Version 0
Level 2
Task 0
Opcode 0
- TimeCreated
EventRecordID 19025
Correlation
- Execution
[ ProcessID] 0
[ ThreadID] 0
Channel System
Computer Jürgen-PC
Security
- EventData
param3
Arguments:
Debugging Details:
FAULTING_IP:
+0
00000000 ?? ???
BUGCHECK_STR: 0x1E
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
Arguments:
Debugging Details:
FAULTING_IP:
+0
00000000 ?? ???
BUGCHECK_STR: 0x1E
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
Gruss V200
