wieviel ist dieses mainboard hier noch ca. wert?
ASRock Motherboard - Product - ALiveNF7G-HD720p R5.0 - Overview
- Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
- NVIDIA® GeForce 7050 / nForce 630A MCP Chipsets
- AMD LIVE!™ Ready
- Supports Dual Channel DDR2 1066 with AM2+ CPU, and DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
- ASRock AM2 Boost: ASRock Patented Technology to boost memory performance up to 12.5%
- Integrated NVIDIA® GeForce7 Series (NV44) DX9.0 VGA, Pixel Shader 3.0, Max. shared memory 256MB
- 1 x PCI Express x16 slot
- Dual VGA Output: Support DVI-D and D-Sub ports by independent display controllers
- Supports HDCP function with DVI-D port, to enjoy better quality with High Definition HDCP Encryption contents
- Supports 720p Blu-ray (BD) / HD-DVD playback
- NVIDIA® PureVideo™ Ready
- 4 x SATAII 3.0 Gb/s, support RAID (RAID 0, RAID 1, RAID 0+1, RAID 5, JBOD), NCQ, AHCI and "Hot Plug" functions
- Supports Gigabit LAN 10/100/1000 Mb/s
- 1 x WiFi/E header
- HDMI_SPDIF header, providing SPDIF audio output to HDMI VGA card, allows the system to connect HDMI Digital TV/projector/LCD devices.
- Chipset embedded HDMI Audio which supports HDMI signal through DVI-D port by using DVI to HDMI adapter (not bundled)
- Windows® Vista™ Premium 2007 Logo Ready
- ASRock 6CH_DVI I/O: 1 x VGA/DVI-D Port, 1 x VGA/D-Sub Port
