Sammelthread Unreal Engine 4
Sammelthread
Nach einem Monat kam nun der erste Hotfix für die UE 4.21 :D
Amanda.Bott;n1558963 schrieb:
UPDATE!
The 4.21.1 Hotfix is now live!
Fixed in 4.21.1
Fixed! UE-66389 [CrashReport] UE4Editor_CoreUObject!CastLogError() [casts.cpp:11]
Fixed! UE-66640 [CrashReport] UE4Editor_Engine!UWorld::IsGameWorld() [world.cpp:6185]
Fixed! UE-66639 [CrashReport] UE4Editor_Engine!FSkeletalMeshObjectGPUSkin::ReleaseResources() [skeletalrendergpuskin.cpp:180]
Fixed! UE-66509 Animation Modifiers that contain a null Animation Sequence value cause the Engine to crash when applied to an Animation Sequence
Fixed! UE-66661 [CrashReport] UE4Editor_Engine!FDerivedDataAnimationCompression::Build() [animcompressionderiveddata.cpp:95]
Fixed! UE-66634 [CrashReport] UE4Editor_UnrealEd!FBlueprintEditorUtils::FindBlueprintForGraphChecked() [blueprinteditorutils.cpp:2275]
Fixed! UE-66344 Building solution in shipping configurations builds invalid targets
Fixed! UE-66753 Editor running with "DebugGame Editor" configuration fails to launch (This happens only on 4.21 via Launcher)
Fixed! UE-66880 Bad code generation in VS2017 v15.7 and 15.8
Fixed! UE-66075 Disabling "Include Debug Files" for a Windows Distribution build does not exclude the debug files
Fixed! UE-66104 GitHub 5237 : Fix missing VS version indicator on .sln icon
Fixed! UE-66042 Remote compile Action RPG for iOS fails with rsync errors - unable to download Manifest.xml from the remote Mac
Fixed! UE-66047 Crash starting a timecode synchronization with Media players (AJA) - Assertion failed: Type != ERangeBoundTypes::Open
Fixed! UE-66051 Can't synchronize Timecode provider with MediaBundle
Fixed! UE-66357 Attempting to start Shootergame with PixelStreaming enabled causes a crash, Assertion failed: IsValid() in SharedPointer.h - nVidia GPU
Fixed! UE-66367 [CrashReport] UE4Editor_BlueprintGraph!UK2Node::RewireOldPinsToNewPins() [k2node.cpp:928]
Fixed! UE-66638 [CrashReport] UE4Editor_Engine!AGameMode::InitGame() [gamemode.cpp:77]
Fixed! UE-66658 [CrashReport] UE4Editor_UnrealEd!FBlueprintEditorUtils::IsLevelScriptBlueprint() [blueprinteditorutils.cpp:3260]
Fixed! UE-66366 [CrashReport] UE4Editor_Core!FTextStringHelper::WriteToString() [text.cpp:1667]
Fixed! UE-66297 Blueprint Structure breaks when the Editor is closed and re-opened if the struct contains variables that are a Class Reference and a Soft Object Reference to a Blueprint
Fixed! UE-66767 K2Node_MakeContainer::PropagatePinType can cause crash
Fixed! UE-65365 Launching on IOS, sessions do not appear in the Session Frontend
Fixed! UE-66292 RecordPerformance Failing to Create Files Due to Missing CSVTools Directory
Fixed! UE-66316 GitHub 5262 : [BUGFIX] Fix for packaging when using custom VULKAN_SDK on GNUX.
Fixed! UE-41727 Linux crash reports are not showing up on crash report website if there is whitespace in the project's path
Fixed! UE-66280 GitHub 5259 : [BUGFIX] First fix to make UnrealVersionSelector work correct on GNUX
Fixed! UE-64772 Warnings Occur During UHT Build Step when Packaging Code Projects
Fixed! UE-66426 dump_syms slows Linux iteration by several minutes
Fixed! UE-66745 UBT: Makefile generator adds "mono" instead of RunMono.sh on Linux
Fixed! UE-66801 Need command line to disable vulkan workaround in Linux
Fixed! UE-66302 GitHub 5260 : Ignore third party downloaded sdks
Fixed! UE-65229 ARM Server binary size has increased between 4.20 & 4.21
Fixed! UE-66922 GitHub 5306 : Fixing a file path bug
Fixed! UE-66103 Creating a code project on Mac will duplicate the project in the Xcode workspace
Fixed! UE-66050 Crash reported when launching the binary Editor on a 2018 iMac Pro
Fixed! UE-66093 Unable to determine home directory for remote user after updating MacOS to Mojave 10.14.1
Fixed! UE-66001 Device is unable to connect to desktop when using RemoteSession
Fixed! UE-65394 StrategyGame - Tapping on in-game UI buttons causes the buttons to disappear on iOS
Fixed! UE-66171 Assertion shortly after opening application on Lenovo S939
Fixed! UE-65399 Launch Images application crashes shortly after launch image is displayed with Assertion: Index>=0 && Index<NumBits BitArray.h on S939
Fixed! UE-65410 Launch images: Landscape crashes on device after loading on Kindle Fire 5th Gen
Fixed! UE-64067 Regression: Shader library size become too small when using -iterate option with little change in material.
Fixed! UE-61045 tvOS packaging fails due to: Error excluding PersistentDownloadDir from backup
Fixed! UE-65408 Minimum iOS version failure reports as invalid provision on IPP
Fixed! UE-66627 Full Screen Native Resolution not supported on new iPad Pro 11-inch and iPad Pro 12.9 inch (3rd generation)
Fixed! UE-66303 Correctly handle package name redirection and localization during material reload
Fixed! UE-66400 Various Vulkan issues
Fixed! UE-66172 Packages Samples Crash on Launch when Running -vulkan
Fixed! UE-66682 [CrashReport] libUE4Editor-VulkanRHI.so!void FVulkanCommonPipelineDescriptorState::SetUniformBuffer<false>(unsigned char, unsigned int, FVulkanRealUniformBuffer const*) [VulkanPipelineState.h:106]
Fixed! UE-66349 [CrashReport] UE4Editor_Renderer!FMaterialShaderMap::IsValidForRendering() [materialshared.h:882]
Fixed! UE-65820 Engine Test crashes during SK_VertexColors test in -Vulkan
Fixed! UE-66124 QA-Promotion animated lights not illuminating target mesh in vulkan
Fixed! UE-66636 Vulkan crash when running ShooterGame Highrise
Fixed! UE-66737 VulkanBackend doesn't handle all infinite constant values
Fixed! UE-66678 [CrashReporter] libUE4Editor-VulkanRHI.so!VulkanRHI::VerifyVulkanResult(VkResult, char const*, char const*, unsigned int) [VulkanUtil.cpp:668]
Fixed! UE-62779 Skylight Intensity Doesn't Behave The Same in OpenGL as with DirectX
Fixed! UE-66290 Progress Percent is removed from UMG Progress Bar when Transform Shear value is changed
Fixed! UE-66074 Minimum iOS Message from Enabling Metal Desktop-Forward Renderer is Inaccurate
Fixed! UE-66333 Crash on Level Load with Sequencer Event
Fixed! UE-66261 Sequence director fires events multiple times if multiple levels are streaming.
Fixed! UE-66897 Sequencer Batch Rendering cannot output multiple render passes in CLI
Fixed! UE-66307 Simulations become invalid after modifying their user parameters in system and emitter editors.
Fixed! UE-66971 CLONE - [CrashReport] UE4Editor_CoreUObject!StaticFindObject() [uobjectglobals.cpp:308]
Fixed! UE-66973 CLONE - Houdini plugin has compile errors
Fixed! UE-66843 Thai fails to shape correctly if the string starts with spaces
Fixed! UE-60696 [CrashReport] UE4Editor_SlateCore!FHittestGrid::FindFocusableWidget<<lambda_3a8b364273a2882da220e6e492096c17>,<lambda_d0075a811a928600995d1b2de6795365>,<lambda_105424556dbaeebf7f5bf9bed3e2f737> >() [hittestgrid.cpp:397]
Fixed! UE-65859 Simple UI Test fails due to screenshot differences in Vulkan
Fixed! UE-65527 Controllers disappear when entering Landscape in VR Mode
Fixed! UE-66353 Vulkan Crash on Startup
Fixed! UE-66522 Incorrect primitive culling with mobile multi-view
Fixed! UE-66329 GitHub 5265 : Removed duplicated WindowsMixedRealityHMD entry
Fixed! UE-65264 Windows Mixed Reality - Setting haptic to 1 and firing haptic causes editor crash
Fixed! UE-66362 [CrashReport] UE4Editor_Engine!HandleInvalidWorldContext() [unrealengine.cpp:12618]
Fixed! UE-65028 ARSharedWorld - "Receiving Preview Image/AR Data" are misleading messages for the client when they are waiting for the host to share their AR space
Fixed! UE-66955 Rebuild Light Maps UAT Commandlet contains null object warnings
REMEMBER: Please report any new bugs you find by following the How To Report a Bug Guide
Das erste Update für die UE4.21 im Jahr 2019 :D
VictorLerp;n1576108 schrieb:
UPDATE!
The 4.21.2 Hotfix is now live!
Fixed in 4.21.2
Fixed! UE-66965 Crash when reverting an Animation Modifier that sets an Animation Sequence variable that does not have a default value by Event on Revert
Fixed! UE-67388 Crash deleting a state machine and then attempting to focus the state machine tab
Fixed! UE-67224 Package fails to save when attempting to replace references in the editor
Fixed! UE-68097 Particle memory can be corrupted leading to a crash
Fixed! UE-67509 Impossible to save assets after change in redirectors
Fixed! UE-67379 GitHub 5343 : update gitignore
Fixed! UE-67390 Source files not rebuilt when headers change
Fixed! UE-66320 Editor crash on re opening a scene containing Step datasmith scene - Assertion failed: Export.ObjectName!=NAME_None || !(Export.ObjectFlags&RF_Public)
Fixed! UE-67195 "Objects named as ""none"" or any other reserved keyword aren't saved after import"
Fixed! UE-66659 [CrashReport] UE4Editor_Engine!FLevelCollection::RemoveLevel() [world.cpp:258]
Fixed! UE-67414 GitHub 5349 : Update World.cpp
Fixed! UE-67239 GitHub 5334 : Fix: Initialize RcNavMeshOrigin in constructor of FRecastNavMeshGenerator
Fixed! UE-67425 GitHub 5350 : FRecastNavMeshGenerator::RcNavMeshOrigin was not initialized on packaged game without ForceRebuildOnLoad
Fixed! UE-67315 [CrashReport] UE4Editor_UnrealEd!FKismetEditorUtilities::AddComponentsToBlueprint() [kismet2.cpp:1490]
Fixed! UE-68435 GitHub 5450 : UE-68262: Remove StaticMesh == nullptr map check
Fixed! UE-68262 Blueprint inherited from StaticMeshActor will fail to compile if StaticMesh is NULL
Fixed! UE-67900 Child Actor Audio Volume Makes UE4 Crash
Fixed! UE-62491 [CrashReport] UE4Editor_Core!FName::InitInternal_FindOrAddNameEntry() [unrealnames.cpp:818]
Fixed! UE-61971 [CrashReport] UE4Editor_UnrealEd!FKismetDebugUtilities::OnScriptException() [kismetdebugutilities.cpp:211]
Fixed! UE-68108 Crash when executing Rename Asset or Duplicate Asset and other functions in Scripted Actions
Fixed! UE-67621 [CrashReport] UE4Editor_CoreUObject!UMetaData::SetValue() [metadata.cpp:351]
Fixed! UE-67611 [CrashReport] UE4Editor_Engine!ULevelScriptBlueprint::CreateLevelScriptNameFromLevel() [levelscriptblueprint.cpp:57]
Fixed! UE-68015 Crash occurs when applying instance changes to blueprint
Fixed! UE-62664 [CrashReport] UE4Editor_Kismet!SSCS_RowWidget::OnNameTextVerifyChanged() [sscseditor.cpp:3063]
Fixed! UE-67979 Create staticmeshnode or instancedstatic mesh node logs FNetGUIDCache warning in editor
Fixed! UE-67075 Touch events are broken on Linux
Fixed! UE-67255 Linux deployment fails if the folder does not exist on the machine
Fixed! UE-67004 Linux users are not able to switch a project's engine version using the UnrealVersionSelector
Fixed! UE-67927 Linux OpenVR lib is not binary compatible with our baseline
Fixed! UE-68057 UnrealVersionSelector path does not expand with the width of UVS
Fixed! UE-67967 UnrealCEFSubProcess compilation is broken on Linux after char16_t changes
Fixed! UE-68017 Launching On To Linux fails with symbol lookup error: /Engine/Binaries/ThirdParty/OpenVR/OpenVRv1_0_16/linux64/libopenvr_api.so: undefined symbol: __dso_handle
Fixed! UE-68390 GitHub 5446 : Exit with error code in Linux scripts when continuation is invalid.
Fixed! UE-68411 Google Plus API needs to be removed from mobile
Fixed! UE-63791 HTML5 cannot connect to local Windows server
Fixed! UE-67234 Crash on Linux and Windows with Vulkan when adding Atmospheric Fog to a Level
Fixed! UE-67631 [CrashReport] libUE4Editor-VulkanRHI.so!FVulkanDevice::CreateDevice
Fixed! UE-64649 Extreme flickering when setting a high screen percentage when using vulkan
Fixed! UE-68489 Fix crash when SlateElement material uses CustomStencil
Fixed! UE-67243 CLONE - Cascade Particles within Animation Notifies Render Incorrect when Destroy Immediately Enabled
Fixed! UE-68109 Crash editor when open the level sequencer after updated 4.20
Fixed! UE-67242 Foliage meshes doesn't follow the geometry planted on
Fixed! UE-63484 Memory Leak In PageAllocator When Packaged
Fixed! UE-67050 Crash in Python when garbage collecting map properties
Fixed! UE-65010 Help & About does nothing in ARVideoSettings, ARSaveLoad, and ARImageDetection
Fixed! UE-68502 Oculus Avatar animation not working
Fixed! UE-68331 Remote Session App has missing icons
Die erste Preview der UE 4.22 wurde heute released, wobei die erste experimentelle Integration von DXR in DirectX 12 mit von der Partie ist ;)
VictorLerp;n1583659 schrieb:
PREVIEW!
Preview 1 of the upcoming 4.22 release is available now on the Launcher and GitHub. We are making this Preview available so that our developer community can try our new features and help us catch issues before the final release. As fixes are implemented, we will release updated previews throughout the development cycle.
Please be aware that preview releases are not fully quality tested, they are still under heavy active development, and should be considered unstable until the final release. Developers should not convert their projects for active development on preview releases. Please test on copies of your project instead.
Links to known and fixed issues for this release are provided below. If you discover any additional issues with this preview release, please report them using the guidelines in the link: How to Report a Bug.
Known & Fixed Issues
NOTE: You may have to restart the launcher if the preview isn't available.
4.22 Preview Summary
This list provides a brief summary of updates in this Preview which may benefit from additional testing. Not all updates may be listed. Full release notes will be made available with the final 4.22 release.
Animation Updates:
  • Animation Budgeting System (Early Access)
  • Animation Sharing Plugin. Added a new plugin which implements an Animation Sharing system. The system is used for reducing the overall amount of animation work required for a crowd of actors.
  • Preview Scene Settings Improvements. Will allow the user to hide Environment Cubemap without disabling lighting
  • Per Platform Properties Improvements. Per Platform Properties have been extended to be allow for setting values based on Target Platform in addition to the Platform Groups.
Audio Updates:
  • New Unreal Audio Engine now on by Default for New Projects
  • TimeSynth. TimeSynth is a new audio clip based synth component focused on providing designers with sample-accurate start, stop, and concatenation sound playback.
  • Layered Sound Concurrency. The Sound Concurrency System now observes multiple settings/groups.
  • Spectral Analyzer for Submixed Added to Real Time Analysis Tools. In addition to the Envelope Follower, designers can now analyze a Submix’s Spectral Energy during gameplay to drive Blueprint automation.
  • Improvements to Sound Asset Importing. We have improved sound asset importing, in addition to supporting multi-channel wav files, Unreal Engine now converts from a variety of sound file formats upon import including AIFF, FLAC, and OGG/Vorbis.
  • Improvements to MIDI Device Plugin. Improvements have been made to the MIDI Device Plugin allowing users to not only process MIDI Device Input, but also send MIDI Messages Out to Devices.
Automation Updates:
  • Gauntlet Improvements
    • Expanded documentation & samples
    • iOS Support
    • Device Service
    • Profile Guided Optimization
    • Report Creation
Dev Tools Updates:
  • Visual Studio 2019. Support for Visual Studio 2019 has been added. By default, UE4 will still use the Visual Studio 2017 compiler if you have it installed.
  • Build Time Improvements. We’ve made a large number of optimizations to UnrealBuildTool and UnrealHeaderTool to improve C++ iteration times.
  • Support for long filenames (Experimental). Historically, paths in windows have been limited to 260 characters, which can cause problems for projects with complex naming conventions and deep hierarchies of assets. The Windows 10 Anniversary Update adds support for much longer filenames, on the condition that the user and each application opt-in to it.
Editor Updates:
  • Subsystems. Subsystems are auto instanced classes with managed lifetimes. These classes provide easy to use extension points where the programmers can avoid the complexity of modifying or overriding engine classes while simultaneously getting Blueprint and Python exposure out of the box.
  • Editor Utility Widgets. Editor Utility Widgets are based on UMG, so you can modify the layout of the Editor user interface, and set up Blueprints for logic just as you can with a UMG widget.
  • Material Analyzer. The Material Analyzer can be found under Window > Developer Tools. If you open the Material Analyzer right when the Editor starts, it will wait for the Asset registry to finish loading.
Gameplay & Scripting Updates:
  • Blueprint Indexing Optimizations. Improved editor startup/load times by deferring Blueprint search data re-indexing work until a global Find-in-Blueprint tab is opened.
Mobile Updates:
  • Mobile Feature Level Preview Improvements
  • Scalability Platform Override for Mobile Play-in-Editor
  • Movable Spotlight support on Mobile
  • SaveGame System iCloud Support
  • Device Output Window Improvements
  • HTML5 Platform Improvements
  • Dithered LOD Transitions on Mobile
  • iOS Preferred Orientation
Networking Updates:
  • Improved Steamworks support. We’ve made several improvements to usability and quality of life for developers of multiplayer games on Steam.
    • Dedicated Servers on Steam can now receive custom names (up to 63 characters) with the new "-SteamServerName" launch argument.
    • Projects can now override the Steam network layer by deactivating the "bUseSteamNetworking" configuration value and setting their NetDriver configurations to the preferred underlying network layer.
    • We have greatly improved the usability of Steam NetDrivers with UE4 Beacons in addition to standard game networking.
    • You can now set certain required Steam values, such as dedicated server names, or the application ID, in your project's Target.cs file. Making changes to these values will no longer require recompiling the engine.
Niagara Updates:
  • Vector Field Data Interface. We reworked the Vector Field Data Interface completely, and now it works the same for both CPU and GPU particles. The Vector Field Data Interface only supports static vector fields.
  • Curl Noise Data Interface. The Curl Noise Data Interface is completely reworked. Unreal Engine 4 now generates procedural curl noise based on an underlying simplex noise function. The results are identical for both CPU and GPU emitters.
  • Detailed Random Number Generation. This feature adds support for deterministic random number generation for both CPU and GPU Niagara emitters.
  • Additional Inputs for Math Operations.
  • Support for Deprecating Scripts. Scripts for modules, dynamic inputs, and functions can now be marked as deprecated in the script editor. Emitters and systems using deprecated scripts will now display errors in the UI, and deprecated scripts will not show up in the menus used to add them.
  • New Initialization Modules
  • Select by Simulation Target Node. A new node is available for use in script graphs for modules, dynamic inputs, and functions which can be used to execute different logic depending on whether an emitter is running in the CPU vector machine or in a GPU compute script.
  • New Collision System. Niagara collisions have been completely rewritten. The tool now supports ray-trace-based CPU collisions, CPU+GPU analytical plane collisions, GPU scene depth, and distance field collisions.
Physics Updates:
  • Clothing Improvements. Minor improvements to cloth have been made:
    • Remap clothing parameters on asset re-import
    • Added feature to copy clothing assets from an existing skeletal mesh
Rendering Updates:
  • Real-Time Ray Tracing and Path Tracing (Early Access)
    • Added ray tracing low level support.
      • Implemented a low level layer on top of UE DirectX 12 that provides support for DXR and allows creating and using ray tracing shaders (ray generation shaders, hit shaders, etc) to add ray tracing effects.
    • Added high-level ray tracing features
      • Rect area lights
      • Soft shadows
      • Reflections
      • Reflected shadows
      • Ambient occlusion
      • RTGI (real time global illumination)
      • Translucency
      • Clearcoat
      • IBL
      • Sky
      • Geometry types
        • Triangle meshes
          • Static
          • Skeletal (Morph targets & Skin cache)
          • Niagara particles support
      • Texture LOD
      • Denoiser
        • Shadows, Reflections, AO
      • Path Tracert
      • Unbiased, full GI path tracer for making ground truth reference renders inside UE4.
  • Runtime Render Graph API
    • Preview of the upcoming Render Graph API, only a small portion of the renderer has been converted.
  • Mesh Drawing Pipeline Refactor
    • This refactor will make the upgrade process more time consuming than normal for licensees who have made custom modifications to private rendering code.
    • Refactor adds auto-instancing at runtime and more efficient renderthread mesh drawing
Sequencer Updates:
  • Take Recorder. Take recorder supports virtual production workflows where fast iteration of recording performances/takes and reviewing previous takes are critical.
  • Sequencer - Network Replication. Level sequence actors that are set to replicate now synchronize their playback time between server and client.
  • Sequencer Tracks
    • Layered Animation
    • Live Link Track
    • Object binding track (aka material track)
    • Multiple object bindings
    • Copy/paste sections
    • Marks (labels, colors, runtime playback, vertical bounds)
  • Movie Scene Capture
    • Composure track/buffers
    • Expose Track/Section to Blueprints
  • Python Support
Virtual Production Updates:
  • Real-Time Compositing with Composure. This release introduces significant new capabilities to the Composure Plugin, making it easier than ever to composite images, video feeds, and CG elements directly within Unreal Engine.
  • OpenColorIO (OCIO) Color Profiles. You can now use OpenColorIO (OCIO) color profiles to transform the color space of any Texture or Composure Element directly within the Unreal Engine.
  • Hardware-Accelerated Video Decoding (Experimental). On Windows platforms, you can now use your GPU to speed up the processing of H.264 video streams. This reduces the strain on the CPU when playing back video streams, which may result in smoother video and may allow you to use higher resolution movie files and more simultaneous input feeds.
  • New Media I/O Formats
  • nDisplay Improvements (Experimental). This release adds several new features that make the nDisplay multi-display rendering system more flexible, handling new kinds of hardware configurations and inputs.
XR Updates:
  • Hololens Remote Streaming Support. Unreal Engine 4 now supports Holographic Remoting through the Windows Mixed Reality plugin.
  • Oculus Quest Support. Unreal Engine 4 now supports the Oculus Quest all-in-one VR gaming system.
Die zweite Preview der UE 4.22 ist heute mit einem eher umfangreichen Changelog online gegangen :)
Amanda.Bott;n1586420 schrieb:
UPDATE!
We have just released Preview 2 for 4.22! Thank you for your continued help in testing the 4.22 build before its official release. As a reminder, the Preview builds are for testing only, and should not be used for the active development of your project.
For a list of known issues affecting this latest preview, please follow the links provided on the first post in this thread.
Fixed in Preview 2
Fixed! UE-67688 One off ensure adding a Pose to the Anim Graph - Ensure condition failed: LUTIndex.IsValidIndex(PoseName.UID)
Fixed! UE-70062 AUDIO: Occlusion Interpolation Time is not functioning
Fixed! UE-69978 AUDIO: New projects are not defaulting to using AudioMixer
Fixed! UE-69907 Loading Visual Studio toast does not close
Fixed! UE-69795 Editor hangs when attempting to create C++ class in QAGame
Fixed! UE-69712 Data Asset Deserialization crash after upgrading 4.19.2 to 421.1
Fixed! UE-69656 Cooker Progress Display Mode does not display Package Names
Fixed! UE-69883 Datasmith Scene Crash On Import
Fixed! UE-69965 DS Data Prep : Compile button at the wrong place
Fixed! UE-70035 DS Data Prep : cosmetic changes missing
Fixed! UE-70034 DS Data Prep : Integrate missing icons
Fixed! UE-70186 Reimporting udatasmith Root scene does not update the geometry after editing the scene in 3DSMax and overwriting the existing udatasmith
Fixed! UE-69991 Datasmith re-import crash - UE4Editor-UnrealEd!UMaterialInstanceConstantFactoryNew::FactoryCreateNew
Fixed! UE-69739 Invalid lightmap settings after Python Datasmith CAD import
Fixed! UE-70040 Compilation warnings with Clang compiler - declaration shadows a field of 'FDatasmithFBXSceneProcessor'
Fixed! UE-69796 DeltaGen importer asks to override LevelVariantSets on reimport
Fixed! UE-69792 Default options of DeltaGen importer do not fill default paths resulting in partial import
Fixed! UE-69801 VRed importer - material properties are not set properly
Fixed! UE-69794 DeltaGen and VRED importer does not import texture
Fixed! UE-70060 GitHub 5554 : change Intellisense to vs2019?
Fixed! UE-69674 Launching onto Android fails with Magic Leap plugin disabled
Fixed! UE-69193 Project specific UE4Commandline.txt is generated and placed in Engine\Intermediate in an installed build
Fixed! UE-69957 Run.UAT cook fails for Shootergame with "Failed to delete file AutomationUtils.Automation.dll"
Fixed! UE-69290 Mac - Crash reporter not showing up for Debug Render commands
Fixed! UE-69878 C++ project packaging and Launch On fails with System.IO.DirectoryNotFoundException for Metadata.dat
Fixed! UE-68840 GLTF - Buster Drone scene animation is busted
Fixed! UE-68727 Box UV generation out of bound
Fixed! UE-69741 VirtualStudio should use FileMediaOutput as a default profile for outputing.
Fixed! UE-69569 Crash importing GLTF materials - !AllocationFlags[Index] [File:...\engine\source\runtime\core\public\Containers/SparseArray.h
Fixed! UE-69626 Datasmith - Some materials are imported outside of the transient package before the finalize.
Fixed! UE-69533 DS Data Prep - Unable to to remove object engine thinks it's in use when it isn't
Fixed! UE-68329 Datasmith GLTF wrong camera position
Fixed! UE-63407 Not a valid row name message appears twice when renaming a data table row to none
Fixed! UE-69838 [CrashReport] UE4Editor-CoreUObject!UObject::Rename(wchar_t const *,UObject *,unsigned int) [Obj.cpp:200]
Fixed! UE-69833 [CrashReport] UE4Editor-UnrealEd!AssetSelectionUtils::BuildSelectedActorInfo(TArray<AActor *,FDefaultAllocator> const &) [AssetSelection.cpp:225]
Fixed! UE-69734 GitHub 5526 : UE-61501: Remove @ in order for tooltip text to be parsed
Fixed! UE-66080 Gameplay Tag Query using NoTagMatch expression does not construct DebugString properly
Fixed! UE-57421 Deprecated Enable Navigation System property visible in World Settings
Fixed! UE-69807 Log Navigation Errors spam after deleting and creating a new Nav Mesh Bounds Volume - rcBuildCompactHeightfield: Out of memory 'chf.spans'
Fixed! UE-69917 stat ai' can crash if UWorld.ControllerList contains nulls
Fixed! UE-69914 Navigation collision gathering can result with UObject that are not reachable during GC
Fixed! UE-69472 Navigation Mesh ignores Hierarchical Instanced Static Meshes using "Build Paths" or the "Build" Button
Fixed! UE-66794 Custom CrowdManagerClass reference is set to none when restarting the Editor
Fixed! UE-66340 Dynamic NavMesh disappears when loading/unloading SubLevels
Fixed! UE-69049 NavOctree crashing with invalid element IDs
Fixed! UE-70120 Aligning Blueprint nodes Horizontally across the Bottom of a node is Aligning from the Middle
Fixed! UE-70103 Blueprint Debugger displays a clone of a watched value when observing it during PIE after triggering a breakpoint
Fixed! UE-69735 Blueprint function with Delegate param fails to compiled in 4.22 - unable to determine expected signature - is the delegate pin connected?
Fixed! UE-70102 Crash Hitting a Breakpoint across Multiple PIE sessions while Watching Array value - watchpointviewer.cpp
Fixed! UE-69877 Can't package a project with Media Framework Utilities enabled - Unhandled exception: System.IO.DirectoryNotFoundException: Could not find a part of the path 'Intermediate\Build\Win64\UnrealPak\Development\Metadata.dat'.
Fixed! UE-69960 Switch media player crashes when changing tracks
Fixed! UE-69935 Switch media player does not seek with open source latent node
Fixed! UE-69682 Media Player: Open Source Latent needs to trigger output pin after Play/Seek is called
Fixed! UE-70046 Windows Server Asserts after Post-Game Roll Over in ShooterGame - Referencing DataChannel.cpp [Line: 2647]
Fixed! UE-66695 Packaging to HTML5 fails when Online Framework is enabled
Fixed! UE-67676 FVoiceCaptureWindows::Init produces incorrect result with empty DeviceName
Fixed! UE-69601 iOS/tvOS packaging fails during building due to missing library lPhysX3CookingProfile
Fixed! UE-69884 Cape physics culling bug in Pixel Streaming Sample
Fixed! UE-70152 Pixel Streaming - Kallari Skins 2 and 3 are utilizing soft shadows rather than hard shadows
Fixed! UE-69812 Unreal Studio projects fail to open due to MeshEditor plugin failing to load
Fixed! UE-69856 GitHub 5541 : WebMMovieStreamer crash: missed string parameter in log line
Fixed! UE-69923 Newly created Windows on Linux are resized after creation
Fixed! UE-69672 Linux: Running Setup.sh Does Not Download the Latest Linux Toolchain
Fixed! UE-64696 Ensure triggered when exiting the editor from PIE, Lhs.CurrentNum == Lhs.InitialNum Error: Array has changed during ranged-for iteration!
Fixed! UE-70164 Ensure when closing the editor after selecting 'Don't Save', Lhs.CurrentNum == Lhs.InitialNum
Fixed! UE-70038 Tiny artifact in curve editors on Mac when moving mouse
Fixed! UE-51711 [CrashReport] Mac crash - UE4Editor-Slate.dylib!PrepassWindowAndChildren(TSharedRef<SWindow, (ESPMode)0>)
Fixed! UE-46425 [CrashReport] Crash on Mac related to cooking for Android - libstdc++.6.dylib!std::_Rb_tree_rotate_left()
Fixed! UE-64286 Zenfone 2 experiences massive rendering artifacts in ES3.1
Fixed! UE-68976 HTML5 Preview Mode uses Android icon
Fixed! UE-69789 Packaging Vehicle Advanced Code for HTML5 fails with incomplete definition of type APlayerController error
Fixed! UE-69753 Multithreaded HTML5 loads into a black screen
Fixed! UE-69737 1st time crash loading a new Preview Rendering Level - Assertion failed: !Material->IsDefaultMaterial()
Fixed! UE-65480 Android Vulkan - template projects render white, pink, and green haze
Fixed! UE-68340 HTML5 Servers crash on connection cleanup due to malformed connection sources
Fixed! UE-60801 Noticeable frame time increases on low end Adreno devices in SunTemple
Fixed! UE-68431 Showing black screen when drawing Distion and DOF on Android
Fixed! UE-70138 Toggling feature level preview whilst building lighting can crash the editor
Fixed! UE-63199 GitHub 5020 : Handle more pixel formats in function ComputeBytesPerPixel
Fixed! UE-70043 Selecting camera actors causes missing view mode shaders to be compiled
Fixed! UE-70009 Volumetric Lightmaps do not work with Landscape texture mapping
Fixed! UE-69967 Fix VisualizeTexture regressions from RDG conversion
Fixed! UE-65703 UE4Editor -vulkan crashes when skeletal mesh is viewed
Fixed! UE-65500 GitHub 5185 : Shadow comparison optimization.
Fixed! UE-66195 Rename misleading Project Setting Metal Desktop-Forward Renderer
Fixed! UE-52553 GitHub 4239 : Vertex fog optimization.
Fixed! UE-68818 Crash with instanced lightmaps
Fixed! UE-67618 GPU scene depth collisions act differently when the niagara editor viewport is open
Fixed! UE-69046 GitHub 5497 : Fix FLinearColor::MakeRandomColor always returning white
Fixed! UE-70080 TakeRecorder plugin causes a Duplicate Level Seqence Object entry in Blueprint Variable Selection Dialog
Fixed! UE-70042 Movie Scene Scripting blueprints do not display the channel type
Fixed! UE-69648 Adding a key to a level sequence does not add the object's current value
Fixed! UE-70134 Clicking the LOD1~ radio button in the static editor doesn't update the viewport to show the correct lod, works in the skeletal mesh editor.
Fixed! UE-70095 Potential for race conditions in startup movies to cause crash
Fixed! UE-69802 Crash when creating a sub level and overwriting a level with the same name - Assertion failed: Renaming an object on top of an existing object is not allowed
Fixed! UE-69759 Editor crashes when using Advanced Copy with Generate Dependencies to copy a niagara system
Fixed! UE-69352 Engine Crashes whenever trying to hide a sublevel.
Fixed! UE-69407 Level Switch viewport button does not correctly display levels with numbers
Fixed! UE-64265 Component Array doesn't update properly when using Text Variables
Fixed! UE-69150 [CrashReport] UE4Editor-UnrealEd!UEditorEngine::CheckForWorldGCLeaks(UWorld *,UPackage *) [EditorServer.cpp:1969]
Fixed! UE-69785 Black flickering artifacts near the edge of the viewport when sculpting landscapes
Fixed! UE-70002 GenerateGlobalizationFiles.bat fails to load ResourceFileGen.ini
Fixed! UE-70124 ConcertPresence base types are visible in the Class Picker
Fixed! UE-70123 Multiuser Presence actors are unset by default
Fixed! UE-69757 Multi User crash when painting foliage
Fixed! UE-70004 Python does now show custom collision channel enum entries
Fixed! UE-69604 Calling Console Commands in Python doesn't execute
Fixed! UE-58720 No feedback when the user attempts to record in a session outside of the editor
Fixed! UE-69282 Media capture (AJA) doesn't grab UMG widgets in standalone mode.
Fixed! UE-69059 OpenColorIO shader DDC key missing shader dependency info
Fixed! UE-67524 r.Vulkan.RHIThread=1 warning when launching onto Lumin
Fixed! UE-69422 Crash entering PIE without Magic Leap SDK referencing delayhlp.cpp:323
Fixed! UE-69269 QAGame -game launches with 'Zero Iteration' message regarding VR Mode
Fixed! UE-68094 Race condition in the late update manager
Fixed! UE-67799 Fix log spam when using a vive wireless adapter
Fixed! UE-69840 Instanced Stereo causes multiple rendering errors
Fixed! UE-66395 [CrashReport] UE4Editor_OculusAvatar!__delayLoadHelper2() [delayhlp.cpp:323]
Fixed! UE-69901 Empty Level Text needs to be fixed up internally and in user-facing text
Vor wenigen Minuten wurde die dritte Preview der UE 4.22 released :)
VictorLerp;n1589055 schrieb:
UPDATE!
"We have just released Preview 3 for 4.22! Thank you for your continued help in testing the 4.22 build before its official release. As a reminder, the Preview builds are for testing only, and should not be used for active development of your project.
For a list of known issues affecting this latest preview, please follow the links provided on the original post in this thread."
Fixed in Preview 3
Fixed! UE-68048 GitHub 5428 : Steam Audio Fixes
Fixed! UE-69882 Non-Spatializied Audio isn't playing in all channels
Fixed! UE-67502 Source Bus: Bypass Volume Scale for Priority and Priority Settings are Placed Under Concurrency Heading but is Unrelated to Concurrency Settings
Fixed! UE-62927 GitHub 4994 : Fix: Stopping FMixerSource can be paused
Fixed! UE-69896 Infinitely waiting for Audio Thread - Log spam when launching QAGame in Standalone Game
Fixed! UE-70484 Editor fails to compile while building UHT - Exec format error - libUnrealHeaderTool-Core.so
Fixed! UE-70079 Datasmith - StaticMeshes lose their material after reimport
Fixed! UE-69680 DS Data Prep - Crash when re-importing mesh
Fixed! UE-70303 Skipped assets during Datasmith Reimport
Fixed! UE-70295 Datasmith Materials no longer Reimport correctly - Datasmith > Reimport Material
Fixed! UE-70297 Datasmith Materials no longer Reimport correctly - Asset > Reimport <Asset>
Fixed! UE-70182 Reimporting actor within Datasmith Root scene breaks Datasmith Actor-Material Connection
Fixed! UE-70426 Datasmith CAD stops reimporting after second iteration
Fixed! UE-70318 Datasmith import takes more memory than 4.21
Fixed! UE-70036 Exported LOD with Datasmith SDK gives strange result at import
Fixed! UE-69425 DS Data Prep - All but one SceneActor erased on execution
Fixed! UE-69254 DS Data Prep - Remove operation improvements - hierarchy modification not reflected
Fixed! UE-70420 Cannot save asset with label containing special character
Fixed! UE-70371 Launch On relinks every time
Fixed! UE-70310 VirtualCamera adds duplicate camera actor in TakeRecorder
Fixed! UE-65226 MeshEditing - Materials are reassigned wrongly on reimport after undo deleting all polygons using the same material
Fixed! UE-70263 VirtualProduction Root Actor doesn't return correct target camera
Fixed! UE-70256 DS Data Prep : missing operators
Fixed! UE-70301 DS Data Prep : Set Generate Lightmap UVs does not work on Actors
Fixed! UE-70254 DS Data Prep - CAD hierarchy flatten on dataprep import
Fixed! UE-70105 Crash on Rhino model
Fixed! UE-70391 Crash in UVPCustomUIHandler::Uninit() on shutdown, preventing Launch from working
Fixed! UE-69912 Crash in Debug Camera (patch provided in comment !)
Fixed! UE-69915 GitHub 5544 : Add `GetDisableSplitscreenOverride` to viewport
Fixed! UE-69969 Crash when opening TM-Nat_UMG map that was packaged with inclusive nativization
Fixed! UE-70311 FEQSParametrizedQueryExecutionRequest logging a erroneous warning
Fixed! UE-70091 Changing the Default Value of BP Struct does not propagate change to existing Blueprint Variables
Fixed! UE-70027 Packaging for HTML with Inclusive Nativization enabled fails
Fixed! UE-61501 No useful tooltip info for Mid node
Fixed! UE-70478 WebM lib requires /LTCG switch on Windows
Fixed! UE-70184 Ensure occurs the first time watching a replay using demoplay command
Fixed! UE-70185 Multiple warnings and errors generated when using demoplay command in ShooterGame
Fixed! UE-70187 ShooterGame: Editor crash when PIEing and attempting to play a replay through console command blueprint referencing Map.h:476
Fixed! UE-70183 Multiple 'Failed to find/spawn actor' warnings when scrubbing replay in ShooterGame
Fixed! UE-70496 Linux clients with -nullrhi do not call UpdateLevelStreaming
Fixed! UE-67931 Engine\Build\IOS includes an expired certificate
Fixed! UE-67529 TVOS - Packaging CPP project fails when "Support Bitcode in Shipping" enabled
Fixed! UE-70386 Google Pixel devices play an abbreviated startup movie
Fixed! UE-70359 DeploymentServerLauncher crash when opening or closing the editor
Fixed! UE-70387 [Match 3] Continuous popping static noise can be heard during gameplay on some Android devices
Fixed! UE-70101 Initial Startup Movie playback stutters on Android
Fixed! UE-69714 Mac installed build fails on step 5/9, Microsoft.Common.targets: error : Command StopDeploymentServer.bat
Fixed! UE-69711 WebTexture asset errors when packaging for Windows (fallout from UE-61554)
Fixed! UE-69257 iOS Device Output Log doesn't connect to attached device on Mac
Fixed! UE-69179 DeploymentServerLauncher crash (various repros)
Fixed! UE-69183 iOS Device Output Log doesn't recover previously disconnected device
Fixed! UE-68966 HTML5 physics objects bounce unexpectedly once disturbed
Fixed! UE-70498 iOS device querying does not work
Fixed! UE-66931 Landscape is Disappearing with Vulkan Enabled
Fixed! UE-68470 Crash w/ Assert Failed when launching PIE VR Preview - Direct3DDevice Error w/ E_INVALIDARG
Fixed! UE-70323 Crash opening a level sequence
Fixed! UE-70300 Velocity vectors incorrect for moving meshes which have MarkRenderStateDirty() called on them every frame
Fixed! UE-69831 Mesh jitter when moving in editor
Fixed! UE-69077 Crash When Material is Set to Deferred Decal with Emissive Decal Blend Mode and Forward Shading Enabled
Fixed! UE-66920 Massive Artifacts and screen flickering when adding DebugCreatePlayers
Fixed! UE-63739 Cubemaps not Reflecting with -vulkan in PIE after changing Reflection Capture Resolution
Fixed! UE-69220 Reimplement view mode overrides for WPO materials
Fixed! UE-70334 Sequence MPC SetVectorParameterValue crash when stopping and starting PIE
Fixed! UE-68624 GitHub 5469 : Ansel plugin updates
Fixed! UE-70523 GitHub 5573 : 4.22 ansel51 - missing pieces
Fixed! UE-69742 Some Houdini Modules are failing to compile
Fixed! UE-69372 Niagara runtime feature level checks are not consistent
Fixed! UE-69005 Editor Crashes when PIE with Vulkan Mobile Preview
Fixed! UE-70349 Starting editor with Raytracing crashes with assert: Id.bValid && !Id.bOneFrameId
Fixed! UE-70312 Integrate DX11 RHI Thread to 4.22
Fixed! UE-70041 Crash stopping sequence on IOS
Fixed! UE-69079 One-Off crash in Raytracing World Normals viewmode: Unhandled Exception: 0x0000087a
Fixed! UE-70180 Values are doubling when setting new keys in Sequencer tracks
Fixed! UE-68959 Gameplay windows from Standalone do not remember their positions properly when there are multiple windows
Fixed! UE-66851 4.21 PIE Issues in High DPI
Fixed! UE-69805 Collections folder shows up when creating new blank project
Fixed! UE-63123 Static HISM gets corrupted lightmap after building lighting if using Lighting Scenario
Fixed! UE-69679 Data Table Reimport - No popup to specify source file
Fixed! UE-70441 Reimport of skeletal mesh LOD > 1 will be reduce if LOD 1 is generated
Fixed! UE-69730 Exporting Then Reimporting a Landscape Layer Weightmap as an .r8 will fail
Fixed! UE-69790 Crash when interacting with newly created landscape, LODData->LodBias == SceneProxy->GetShaderLODBias() [File:/LandscapeRender.cpp] [Line: 3452]
Fixed! UE-69629 Crash sculpting on Landscape Streaming Proxy
Fixed! UE-69466 [CrashReport] UE4Editor-Landscape!FLandscapeComponentSceneProxy::BuildDynamicMeshElement
Fixed! UE-69217 LOD setting from World Composition do not work as expected. LOD distance seems not applied and last LOD is not remaining from far distance.
Fixed! UE-70196 GitHub 5564 : Fixed crash while building grass in editor
Fixed! UE-70296 Cannot gather engine sources in out-of-tree projects
Fixed! UE-69606 Simple collisions are regenerated each time the mesh editing tool is used
Fixed! UE-70331 Multi-User Editing Settings VRAvatar class is missing a space
Fixed! UE-70320 Update MultiUser icons for 4.22 Release
Fixed! UE-69836 [CrashReport] UE4Editor-CoreUObject!UObject::Rename(wchar_t const *,UObject *,unsigned int) [Obj.cpp:200]
Fixed! UE-70438 Double click behavior of Editor Widgets is inconsistent
Fixed! UE-70281 UMG Widgets duplicating UMG buttons
Fixed! UE-70244 Crash in FVPUtilitiesEditorModule::ShutdownModule() in Debug|Editor config on editor shutdown/exit
Fixed! UE-68508 Oculus 1.31 - VR Preview mirror window is pǝddᴉlɟ
Fixed! UE-62761 Warning: MessageBox: No Vulkan entry points found! opening project on MagicLeap
Fixed! UE-70193 Mobile Multi-View is rendering the same view for both eyes
Fixed! UE-70219 Editor Requires Android SDK to Package for Lumin Platforms
Fixed! UE-70306 Error building QAGame for Magic Leap
Fixed! UE-70084 Magic Leap blueprint Functions/Enums fail to load properly when reopening a project
Fixed! UE-69932 Ensure condition failed: VRSystem && VRCompositor after shutting down SteamVR while still in Editor
Fixed! UE-69562 Shadows on instanced meshes are incorrect when ISR is enabled
Fixed! UE-69123 Lumin media project crashes on device with assertion failed: Pair != nullptr
Fixed! UE-69112 [CrashReport] UE4Editor-SteamVR!FSteamVRHMD::UpdatePoses() [SteamVRHMD.cpp:672]
Fixed! UE-68991 Ensure 'CachedShader == PixelShader->Resource' when launching onto HMD for the first time in Editor
Fixed! UE-66792 Simple HMD VR preview left eye color issue
Fixed! UE-60968 MagicLeap Install_ProjectName.command unable to run due to invalid permissions
Fixed! UE-70308 Magic Leap crash on device: FVulkanDescriptorSetWriter::WriteBuffer
Fixed! UE-69922 Rendertarget Swapchain spam when launching VR Preview or VRMode to the Oculus Rift HMD
Fixed! UE-69769 Send Console commands on tvOS
Fixed! UE-70309 Disk size taken by Linux Unreal Editor regressed significantly
Eine weitere sehr umfangreich gefixte Preview der UE 4.22 wurde heute released :)
VictorLerp;n1591638 schrieb:
UPDATE!
We have just released Preview 4 for 4.22! Thank you for your continued help in testing the 4.22 build before its official release. As a reminder, the Preview builds are for testing only, and should not be used for the active development of your project.
Fixed in Preview 4
Fixed! UE-70786 Crash using Facial Animation Importer referencing CurveTable.cpp:543 Anim UEENGQA-24195, regression
Fixed! UE-67687 Anim graph nodes are not properly named in the Asset Override Editor Anim regression
Fixed! UE-67791 Crash attempting to reorder a Preview Mesh Collection array within the Animation Editor - Assertion failed: IsValid() in SharedPointer.h at Line 849 Anim crash
Fixed! UE-68762 Convert CharacterBP to Spawnable in Sequencer cause crash Anim - Animation
Fixed! UE-69655 Crash undoing the renaming of an Animation Curve that had been deleted - Assertion failed: (Index >= 0) & (Index < ArrayNum) in Array.h Line 611 Anim - Animation crash
Fixed! UE-68490 Retargeting an Animation to a Skeleton with a Virtual Bone causes the Engine to crash Anim - Animation crash, liveissue
Fixed! UE-69896 Infinitely waiting for Audio Thread - Log spam when launching QAGame in Standalone Game Audio -game, Audio, Device, LogSpam, Standalone, UEENGQA-24211
Fixed! UE-69577 Audio cuts out and desyncs during garbage collection Audio
Fixed! UE-66165 CRASH: AUDIO: Client will crash when hitting Play when using Steam Audio in Spatial Audio Temple Audio Audio
Fixed! UE-60718 GitHub 4806 : Fixed bug where ImageComparer was comparing ImageA pixel value agains? Automation GitHub
Fixed! UE-68680 AXF material import diffuse and roughness are wrong on interior fabric Datasmith
Fixed! UE-70173 Mesh Editing window is named Secondary Toolbar when closed and reopened Datasmith
Fixed! UE-70181 Ensure after deleting Actor from "Re-Spawn Deleted Actor" with the original actor still in the scene Datasmith - 3dsMax Datasmith, Enterprise, Reimport, UEENGQA-24223
Fixed! UE-70805 Crash importing JT file Datasmith - CAD
Fixed! UE-69406 Actors from CAD import lose their StaticMesh on reload after reimport Datasmith - CAD Regression
Fixed! UE-66896 Reimport LOD on reimported Datasmith Mesh adds extra Material slots Datasmith - CAD
Fixed! UE-66373 Surface orientation in UE does not match the one in Rhino Datasmith - CAD
Fixed! UE-70712 Static meshes imported with Datasmith have their Collision Complexity set to 'Use simple collision as complex' Datasmith - Core Lib Regression
Fixed! UE-70039 Crash create new level after converting a DatasmithSceneActor to Blueprint Datasmith - Core Lib Crash
Fixed! UE-70036 Exported LOD with Datasmith SDK gives strange result at import Datasmith - Core Lib Regression
Fixed! UE-69645 Datasmith - Deleted meshes (from exported file) are not removed from Level on reimport Datasmith - Core Lib Regression
Fixed! UE-70437 Crash reimport twice a Datasmith asset - UE4Editor_DatasmithImporter!UDatasmithImportFactory::PreReimportStaticMesh() [enterprise\plugins\editor\datasmithimporter\source\datasmithimporter\private\datasmithimportfactory.cpp:607] Datasmith - Core Lib Crash, Regression
Fixed! UE-69048 AxF textures are too desaturated and a bit darker Datasmith - MDL
Fixed! UE-68436 Some MDL materials are incorrect with the procedural approach Datasmith - MDL
Fixed! UE-70609 DeltaGen and VRED importers Visibility Variants does not work Datasmith - Deltagen, Datasmith - VRed
Fixed! UE-70509 RPCUtility cannot be built in 4.22 DevTools NeedsTest, licensee, liveissue
Fixed! UE-70924 UnrealLightmass and ShaderCompileWorker fail to build - AgentInterface.pdb doesn't exist DevTools BlocksTesting, Regression, ReleaseBlocker
Fixed! UE-70837 Opening the Samples/Sandbox/UniqueBuildEnvironment Editor creates a Samples/Sandbox/Engine/DerivedDataCache folder DevTools
Fixed! UE-70824 Warning toast in UniqueBuildEnvironment "Project names must not be longer than 20 characters" DevTools
Fixed! UE-70825 Packaged UniqueBuildEnvironment project fails to open descriptor file UniqueBuildEnvironmentGame.uproject DevTools
Fixed! UE-70911 Unable to build lighting from editor with unique build environment DevTools
Fixed! UE-70785 Lots of functionality broken when building editor with a unique build environment DevTools
Fixed! UE-70647 Variant Manager - variant blueprint event are fired even when not playing Enterprise copytorelease
Fixed! UE-70085 White Frame on image plates on shot boundaries in Simple Composure sample Enterprise
Fixed! UE-69016 Crash deleting level when asset folder was renamed (UE4Editor_Core!FDebug::CheckVerifyFailedImpl()) Enterprise Crash
Fixed! UE-68600 Lights radius and intensity wrong after glTF import Enterprise
Fixed! UE-70263 VirtualProduction Root Actor doesn't return correct target camera Enterprise
Fixed! UE-69555 Datasmith - Instances from ForestPack does not show in the viewport after import Datasmith - Core Lib, Enterprise Regression
Fixed! UE-67431 MeshEditing - Crash editing a LOD after deleting polygons on another LOD - Assertion failed: (Index >= 0) & (Index < ArrayNum) Enterprise Crash
Fixed! UE-70072 User Defined Struct causing crash due to accessing freed memory when using Stompmalloc Gameplay NeedsTest, crash, licensee, liveissue
Fixed! UE-70467 Child Actors are not replicated to clients when the parent blueprint is nativized Gameplay BP_ChildActorComponent, BP_Nativization, NeedsTest, liveissue, regression
Fixed! UE-69972 GitHub 5546 : UE-69951: World nullptr check in CheckForErrors Gameplay GitHub
Fixed! UE-69834 [CrashReport] UE4Editor-Kismet!FindFieldChecked<UProperty>(UStruct const *,FName) [UnrealType.h:4718] Gameplay TopCrash, VerifyAfterRelease, crash, liveissue
Fixed! UE-70642 Compile error when Blueprint Interface returns a map type variable Gameplay - Blueprint BP_Interface, NeedsTest, liveissue
Fixed! UE-69951 WorldSettings Blueprint crashes editor when saved/compiled Gameplay - Blueprint crash, licensee, liveissue
Fixed! UE-70486 UE4Editor-CoreUObject!FUObjectSerializeContext::PRIVATE_PatchNewObjectIntoExport Gameplay - Blueprint TopCrash, VerifyAfterRelease, crash, liveissue, preview
Fixed! UE-70471 Crash when changing the variable type of a variable used in a blutility function Gameplay - Blueprint BP_Blutility, Crash, NeedsTest, licensee, liveissue
Fixed! UE-70513 [CrashReport] UE4Editor-CoreUObject!FLinkerLoad::PRIVATE_PatchNewObjectIntoExport(UObject *,UObject *) [LinkerLoad.cpp:557] Gameplay - Blueprint Compiler TopCrash, crash, liveissue, preview
Fixed! UE-70663 WebM movie streamer crashes when playing 2 or more startup movies Media Framework Linux_game
Fixed! UE-70649 Deprecate Google+ APIs Online - OSS
Fixed! UE-63925 Move Vivox/VoiceChatFeature to engine plugin Online - Voice TechDebt, voice
Fixed! UE-70534 [TM-RectLights] Stationary Lights cast no shadows Platform - Console Regression, UEENGQA-24208
Fixed! UE-70759 Using multiple scene render targets of differing dimensions in a frame causes issues Platform - Console
Fixed! UE-70622 MachineId field in Linux crash reports can be empty or incorrect Platform - Linux Linux_server
Fixed! UE-69259 Engine can crash on Linux due to clock going backward Platform - Linux Linux_server, PostFC
Fixed! UE-70164 Ensure when closing the editor after selecting 'Don't Save', Lhs.CurrentNum == Lhs.InitialNum Platform - Mac Ensure, UEENGQA-24223
Fixed! UE-51711 [CrashReport] Mac crash - UE4Editor-Slate.dylib!PrepassWindowAndChildren(TSharedRef<SWindow, (ESPMode)0>) Platform - Mac Crash, TopCrash, VerifyAfterRelease, liveissue
Fixed! UE-70482 Startup Movies in Mac packages attempt to load video with incorrect video player plugin Platform - Mac StartupMovie
Fixed! UE-70666 Vulkan crash on Samsung Note9 Adreno Platform - Mobile
Fixed! UE-70664 Post process Global Illumination doesn't work on mobile preview, device. Platform - Mobile Mobile, PostProcess
Fixed! UE-70653 Editor hangs for a few seconds when entering iOS commands in device output log Platform - Mobile
Fixed! UE-70592 GitHub 5577 : UE-70558: Enable small icons for Preview modes Platform - Mobile GitHub
Fixed! UE-70558 Preview Mode Button Does Not Have an Icon When Small Toolbar Icons is Enabled Platform - Mobile NeedsTest, liveissue, preview
Fixed! UE-70475 Packaging for tvOS from Windows fails with rsync error unless iOS is packaged first Platform - Mobile BlocksTesting, Regression, UEENGQA-24204
Fixed! UE-70452 Windows to iOS fails to launch-on due DeploymentServerLauncher.exe missing from DotNET iOS Binaries Platform - Mobile BlocksTesting, Regression
Fixed! UE-70447 Sun is rendering as a black dot when behind a wall in TM-ShaderModels Platform - Mobile UEENGQA-24216, compat
Fixed! UE-70394 Nearest Filtering on Vulkan doesn't work on some kinds of Android Devices Platform - Mobile
Fixed! UE-70234 Error: Failed to connect to deployment server at 127.0.0.1:41000 - DeploymentServer not running Platform - Mobile Regression
Fixed! UE-69985 Black screen on mobile at start app when not using startup movie or preload screen Platform - Mobile licensee
Fixed! UE-62851 Remote Build pre-check error does not appear when missing required arguments Platform - Mobile
Fixed! UE-69428 Device Output Log should no longer be experimental Platform - Mobile
Fixed! UE-70045 GPU Particles do not render on Magic Leap Platform - Mobile, Virtual Reality
Fixed! UE-70748 [CrashReport] UE4Editor-Renderer!AddPrimitiveToUpdateGPU(FScene &,int) [GPUScene.cpp:365] Rendering TopCrash, VerifyAfterRelease, crash, liveissue, preview
Fixed! UE-70703 Crash opening ArchVis sample: EXCEPTION_ACCESS_VIOLATION writing address 0x00000048 Rendering Crash, Regression
Fixed! UE-70874 [CrashReport] UE4Editor-Renderer!TBitArray<FDefaultBitArrayAllocator>::Realloc(int) [BitArray.h:904] - Out of Memory Rendering Preview, TopCrash, crash, liveissue
Fixed! UE-70569 Crash When Changing to Landscape Paint Tool With a Material Function for the World Position Offset of the Landscape Material Rendering crash, liveissue, preview, regression
Fixed! UE-70552 White screen displays when transitioning between Backplate Textures during PIE of Simple Composure Rendering Regression, SimpleComposure, UEENGQA-24208
Fixed! UE-70525 [CrashReport] UE4Editor-Engine!FMaterial::GetShader(FMeshMaterialShaderType *,FVertexFactoryType *,bool) [MaterialShared.cpp:1886] - GetVelocityPassShaders Rendering TopCrash, crash, liveissue, preview
Fixed! UE-70118 PixelData->IsDataWellFormed crash when rendering a movie sequence with Vulkan in HDR Rendering Crash
Fixed! UE-70126 Movies rendered with vulkan are corrupted Rendering, Sequencer Regression
Fixed! UE-66964 Raytraced Distance Field Direct Shadows are Flickering when running with Vulkan Rendering Regression, UEENGQA-23391, Vulkan
Fixed! UE-66948 Flickering shadows in Vulkan Rendering Regression, UEENGQA-23391
Fixed! UE-70409 Investigate Render Target performance differences in dev-rendering vs 4.21 Rendering
Fixed! UE-70492 Cooked content results in crash on launch of QAGame.exe Rendering Crash, LiveCrash, Regression, TopCrash, preview
Fixed! UE-69546 Attempting to add a Cooked Material to the Viewport crashes with Assertion failed: SerializeNum >=0 in Array.h Rendering crash, regression
Fixed! UE-70720 Crash When Building Lighting for a Level with Previously Purged Lightmaps Rendering crash, liveissue, preview, regression
Fixed! UE-70526 [CrashReport] UE4Editor-Renderer!FDeferredShadingSceneRenderer::RayTraceTranslucencyView(FRDGBuilder &,FViewInfo const &,FRDGTexture const * *,FRDGTexture const * *,int,int,float) [RayTracingTranslucency.cpp:424] Rendering - Ray Tracing TopCrash, crash, liveissue, preview
Fixed! UE-70033 PSO Crash using LightPropogationVolumes in Dx12 Rendering - RHI Assert, Crash
Fixed! UE-70147 [CrashReporter] UE4Editor-D3D12RHI!CreatePipelineStateFromStream(ID3D12PipelineState * &,ID3D12Device2 *,D3D12_PIPELINE_STATE_STREAM_DESC const *,ID3D12PipelineLibrary1 *,wchar_t const *) Rendering - RHI Preview, TopCrash, crash, liveissue
Fixed! UE-70722 Add recording frame rate setting Sequencer
Fixed! UE-70598 Geometry cache not playing back after converting to a spawnable Sequencer copytorelease
Fixed! UE-70562 Crash after deleting Editor Utility Widget and accessing it from Window menu Tools liveissue
Fixed! UE-70108 Unhandled exception in FOpenColorIOEditorModule during editor shutdown when cooking Tools Crash, TopCrash, UEENGQA-24201, liveissue, preview
Fixed! UE-69808 Unable to select your own session after opening Session Frontend Tools
Fixed! UE-70700 Text fields stay highlighted after completing changes to them Tools Regression, UEENGQA-24195
Fixed! UE-70917 Filtering by collection is broken Tools - Content Browser regression
Fixed! UE-70763 Renaming an item while another item's rename field is present will crash Tools - Content Browser Crash, Regression, UEENGQA-24195
Fixed! UE-69542 Blueprints created by Advanced Copy do not have their references updated Tools - Content Browser AdvancedCopy, NeedsTest, PostFC
Fixed! UE-70436 Crash while saving assets created by Advanced Copy while opening a level Tools - Content Browser AdvancedCopy, crash
Fixed! UE-59256 Foliage: when applying a scale to either painted instance or spawned from a procedural volume the LOD do not take it into consideration Tools - Landscape
Fixed! UE-70784 Crash in LocalizationDashboard related to FLocalizationGatherPathRootUtil::GetResolvedPathRootDisplayName Tools - Localization crash
Fixed! UE-70811 material instance parameters can become hidden and impossible to unhide Tools - Material Editor
Fixed! UE-70863 Multi-user Plugin does not have a Small Toolbar Icon Tools - Multi-user
Fixed! UE-70291 nDisplay multiviewport crashes on run with Assertion Failed: Array index out of bounds: X from an array of size X Tools - nDisplay Assert, UEENGQA-24200
Fixed! UE-69604 Calling Console Commands in Python doesn't execute Tools - Python NeedsTest, PostFC, licensee, liveissue
Fixed! UE-70599 Missing DerivedDataCache in Unreal Studio binaries Tools - Studio - Content and Templates Regression
Fixed! UE-69317 Attempting multiple simultaneous drags on the same Widget causes app to crash - !this->DragDropContent.IsValid() in SlateApplication.cpp Tools - UMG crash
Fixed! UE-70510 Update RHI API to help deprecation Virtual Production
Fixed! UE-70767 Compile failure in XRTrackingSystemBase in Release-4.22 Virtual Reality
Fixed! UE-70844 Crash on Lumin with desktop rendering in TM-Shadermodels Virtual Reality UEENGQA-24208
Fixed! UE-69036 Terminating a Lumin project that was launched on ends with "Launch Failed" Virtual Reality NOT_IntegrationBlocker, Regression, UEENGQA-23881
Fixed! UE-69044 Lumin Launch on fails when Cook by the Book - VulkanMemory.cpp Virtual Reality NOT_IntegrationBlocker, Regression, UEENGQA-23881
Fixed! UE-70389 WMR - Crash with Windows Mixed Reality plugin enabled and HMD connected Virtual Reality ReleaseBlocker
Fixed! UE-70276 Distortion rendering not working in TM-VRSmoke when ISR is enabled Rendering, Virtual Reality
Fixed! UE-69839 Lumin fails to launch with assert: ICU data directory was not discovered Virtual Reality UEENGQA-24211
Fixed! UE-69840 Instanced Stereo causes multiple rendering errors Virtual Reality InstancedStereo, Regression, ReleaseBlocker, UEENGQA-24211, VRPreview
Fixed! UE-46640 Dismissing "Place phone into daydream headset" leaves app at black screen Virtual Reality
Fixed! UE-70511 Update RHI API to help deprecation
Die UE 4.22 scheint wieder ein Release mit vielen Preview Fasen zu werden :ugly:
Amanda.Bott;n1594381 schrieb:
UPDATE!
We have just released Preview 5 for 4.22! Thank you for your continued help in testing the 4.22 build before its official release. As a reminder, the Preview builds are for testing only, and should not be used for the active development of your project.
Fixed in Preview 5
Fixed! UE-70731 SkeletalMeshReduction Plugin missing from Mac and Linux
Fixed! UE-70753 Merging actors duplicates materials for some LOD levels
Fixed! UE-64409 [CrashReport] UE4Editor_Engine!USkeletalMeshComponent::ComputeRequiredBones() [skeletalmeshcomponent.cpp:1482]
Fixed! UE-70752 Removing an LOD from a SkeletalMesh will not update in an Animation Sequence until the LOD is changed
Fixed! UE-67281 Ensure compressing animation using commandlet - !AnimSeq->CompressionScheme->IsA(UAnimCompress_Automatic::StaticClass())
Fixed! UE-67608 [CrashReport] UE4Editor_Engine!UAnimSequence::GetBonePose() [animsequence.cpp:1423]
Fixed! UE-71016 UE Editor assertion failed in proxy generation
Fixed! UE-68800 Textures and Materials have their merged actor's name appended to their names
Fixed! UE-71048 UE Editor assertion failed in proxy generation
Fixed! UE-70687 No warning message displays when no actors are selected in the merge actor window
Fixed! UE-69491 [CrashReporter] UE4Editor-Engine!FBoneContainer::CacheRequiredAnimCurveUids(FCurveEvaluationOption const &) [BoneContainer.cpp:263]
Fixed! UE-67216 Compression codec can be none which causes an ensure when compressing an animation - Ensure condition failed: bCompressionSuccessful
Fixed! UE-67555 Ensure when an animation blueprint is utilizing a Live Link pose node while the preview viewport is setup for live link
Fixed! UE-68663 Crash after reimporting an Alembic file multiple times - Unhandled Exception: EXCEPTION_ACCESS_VIOLATION
Fixed! UE-68388 Animation Curves can playback incorrectly when compressing the animation with the Uniformly Sampled codec
Fixed! UE-67601 [CrashReport] UE4Editor_Persona!FTimingRelevantElement_NotifyStateEnd::GetElementTime() [sanimtimingpanel.cpp:556]
Fixed! UE-69945 Crash entering PIE when AnimationSharingSetup doesn't have a valid/enabled state that is trying to be played - Assertion failed: Components.IsValidIndex(PermutationIndex)
Fixed! UE-70017 Skeletal Mesh snaps to its reference pose when blending from one animation to another while using an Animation Sharing setup
Fixed! UE-69069 Crash during PIE when a blendspace has an animation sequence with a missing sync marker
Fixed! UE-70213 Crash when returning to a previous state in an Animation Sharing Setup - Assertion failed: Instance.bActive
Fixed! UE-70878 Crash starting PIE when two Animation Sharing states define the same state
Fixed! UE-70451 Anim Sharing Setup variables can be set to negative values
Fixed! UE-70229 Crashing running out of memory when entering pie when Num Random Instances is set to a negative value - Error: Direct3DDevice->CreateShaderResourceView failed
Fixed! UE-70702 Recording an Animation from Persona is causing LogLinker Warnings when creating a new Animation Object
Fixed! UE-65147 GitHub 5167 : Fix infinite loop while building HLOD proxy meshes
Fixed! UE-69903 Using a mono source sound with a stereo source bus fails to play sound
Fixed! UE-69904 Sounds Sent Through Source Buses Play Distorted and Crackling Especially When Downmixed
Fixed! UE-63936 Audio: CRASH: Crash playing TimeSynth that hasn't been activated
Fixed! UE-68765 GitHub 5474 : Resetting destination values when removing patches from Modulation Matrix
Fixed! UE-70936 MeshEditing - Viewport does not update LOD after editing LOD
Fixed! UE-70964 ies texture files only link to datasmitharealight types
Fixed! UE-70032 IES texture asset not persisted
Fixed! UE-70428 Wrong normals on landscape imported via Datasmith
Fixed! UE-71183 Datasmith area light attribute gets reset upon reimport
Fixed! UE-71175 [CrashReport] UE4Editor-UnrealEd!UFactory::ImportObject(UClass *,UObject *,FName,EObjectFlags,FString const &,wchar_t const *,bool &) [Factory.cpp:187]
Fixed! UE-70967 Editor crashes when reimporting asset while in Mesh Editing mode
Fixed! UE-71187 Datasmith menu entry not available on point light
Fixed! UE-71296 Re-importing udatasmith scene doesn't update World Outliner for Pre-Existing Scene in the Level
Fixed! UE-69265 DS Data Prep - Query Get Asset generate Invalid Lightmap
Fixed! UE-70729 Missing triangles for CAD tessellation of long objects
Fixed! UE-71146 Datasmith CAD - Freeze loading a Rhino file
Fixed! UE-68986 Crash applying defeaturing - Fill through holes - on cube - {UE4Editor_Core!__TBB_LockByte()}
Fixed! UE-70723 Visual Dataprep - Texture assets get corrupted on save - invalid data
Fixed! UE-71061 Visual Dataprep - Texture assets can't be reloaded - Failed import for Texture2D
Fixed! UE-71108 Datasmith override on Lights lost on second reimport
Fixed! UE-71150 Visual Dataprep - Crash running SetConvexDecompositionCollision on a plane - UE4Editor_EditorScriptingUtilities!UEditorStaticMeshLibrary::SetConvexDecompositionCollisions()
Fixed! UE-69647 Datasmith Dataprep - Can select glTF, MDL, VRed and DeltaGen importer in import settings
Fixed! UE-71109 Datasmith override on Exposure are not recorded
Fixed! UE-71038 Corrupted texture after a datasmith scene re-import
Fixed! UE-71085 Double Variant Manager entry in Window top menu
Fixed! UE-70970 Creating a new C++ class in Sandbox/Build/BuildTest produces an ensure FModuleManager::Get().QueryModule and never shows the C++ sources
Fixed! UE-71159 Minimized Live Coding Console is not summoned from "Show Console" dialogs
Fixed! UE-71084 Editor can hang when Live Coding is set to Startup: Manual and a compile is triggered
Fixed! UE-71128 Live Coding Compile notification hides behind Editor on subsequent editor launches
Fixed! UE-71076 After closing the Live Coding Console, it does not re-appear from selecting "Show Console" on Compile Notification
Fixed! UE-71077 Live Coding Compiles can queue one extra compile
Fixed! UE-71179 Blueprint Projects have the Compile Dropdown, but no Compile Button
Fixed! UE-71058 Generate Project Files process fails if SwarmAgent.exe is not present
Fixed! UE-71256 Live Coding Compile fails to Hot Reload Binary Code project
Fixed! UE-71257 Live Coding HotReload completes with Linker Warnings
Fixed! UE-71274 Live Coding - Some form of communication that including Engine, Engine Plugin Modules in Binary is invalid
Fixed! UE-71126 Live Coding - Startup Project Settings should be Editor Settings
Fixed! UE-71089 IDE not Detected in Editor when creating C++ Classes and Components
Fixed! UE-71070 Option to Create Code Projects is Available in Project Browser without IDE Installed
Fixed! UE-71279 Console files in ShooterGame Launcher Download
Fixed! UE-71287 Triggering a Live Coding Compile when two Live Coding Consoles are running starts compiling on both, should limit to one
Fixed! UE-71270 Live Coding Console log is spammed with incorrect "Live coding ready - Save changes and press Ctrl+Alt+F11 to re-compile code" when loading Engine Modules
Fixed! UE-71269 Some visual feedback that a hidden Live Coding Console loading is causing the Editor to hang
Fixed! UE-71399 Live Coding does not load Project Plugin Modules
Fixed! UE-71379 Show Console button disabled until first Live Coding compile is triggered, when Live Coding set to automatically start
Fixed! UE-71359 When LiveCoding set to Startup:Manual, Compile button triggers a Legacy compile
Fixed! UE-71362 Unable to disable LiveCoding from the Compile dropdown
Fixed! UE-71116 UBT performance regressions in 4.22
Fixed! UE-71191 cl-filter fails to filter out including messages from non-English Visual Studio versions
Fixed! UE-71088 MediaCapture break the viewport if the capture stopped unexpectedly
Fixed! UE-70871 Unable to save content after a Datasmith revit import - not have sufficient permission to save
Fixed! UE-64016 Smoothing groups wrong after setting static mesh as LOD of another Static Mesh
Fixed! UE-70578 Crash(Assert) CurrentGWorld != PlayWorld || bIsSimulatingInEditor
Fixed! UE-70487 Calling ServerTravel with bShouldSkipGameNotify set to false causes a crash
Fixed! UE-70637 ResavePackages commandlet breaks sublevel translation
Fixed! UE-71281 [CrashReport] UE4Editor-CoreUObject!FUObjectSerializeContext::PRIVATE_PatchNewObjectIntoExport(UObject *,UObject *) [UObjectThreadContext.cpp:64]
Fixed! UE-71409 Blueprint Function Override menu is not searchable as all other context menus are
Fixed! UE-69489 Crash setting Child Actor Class on Add Child Actor Component node
Fixed! UE-68365 ForcePositionUpdate warnings appear when a client connects to a server and does not move
Fixed! UE-71134 ShooterGame startup movie does not have audio
Fixed! UE-70104 FileMediaOutput renders blank image when use from the Media Capture Render Target
Fixed! UE-71023 WebM: audio gets out of sync after seeking
Fixed! UE-70792 Binary build missing VivoxCoreSDK_UPL.xml causing Android Packaging to fail
Fixed! UE-71029 MallocBinned3 can't be disabled via project TargetSettings
Fixed! UE-71407 NVN_TEXPKG_STORAGE_FLAGS_SPARSE isn't always being used when cooking textures.
Fixed! UE-69729 GPU rendering debug crash shows up in Crash Reporter as an Assertion
Fixed! UE-66032 Max Draw Distance Can't Be Set Again Until Set Back to Default
Fixed! UE-69994 Some mono dependencies not included with editor for centOS
Fixed! UE-70131 Linux EGL device selection logic seems broken
Fixed! UE-67798 Playing video in the Editor's Media Player on a Mac results in a degradation in quality with some noticeable banding present
Fixed! UE-71066 Standalone game quits immediately after opening on Mac.
Fixed! UE-70976 MediaFrameworkTest TestVideo_Small does not play when selecting play
Fixed! UE-70612 Red line appears on drop-down boxes in Project Settings while window is docked with high DPI support enabled
Fixed! UE-70172 Unresponsive editor process left in Mac dock after closing the editor
Fixed! UE-71006 MediaFrameworkTest videos will not loop in reverse on Mac
Fixed! UE-71327 GitHub 5615 : Fix quotes on SetupMono.sh for Mac
Fixed! UE-69971 Preview Feature Level not applied to Cascade viewport
Fixed! UE-69976 Preview Feature Level not applied to Blueprint Component viewport
Fixed! UE-68313 Advertising Identified (IDFA) code for iOS should be optional in the Engine
Fixed! UE-69825 SM4 Preview Rendering Level toggle has placeholder icon
Fixed! UE-69918 ScreenPosition gives inconsistent UV in ES3_1 when screen size is changed or in some Android device.
Fixed! UE-71090 PLCrashReporter iOS Bitcode packaging Error
Fixed! UE-70402 Mobile projects crash with Event Driven Loader disabled
Fixed! UE-66204 iOS and tvOS errors in Application Loader to Apple: 'Invalid Code Signing Entitlements' with iCloud
Fixed! UE-69786 Installed Build fails to Build Tools CS - error: Command 'StopDeploymentServer.bat
Fixed! UE-70734 DeploymentServer: System.IO.IOException: Unable to write data to the transport connection
Fixed! UE-70418 Apps Freeze/Crash shortly after open on Devices with 1GB Memory
Fixed! UE-71231 Android external storage permission request interrupts startup sequence on some apps
Fixed! UE-69738 Metal crash occurs when observing M_Tessellated - Assertion failed: PrologueEncoder [File:/MetalStateCache.cpp] [Line: 2068]
Fixed! UE-70623 Crash opening TM-VolumetricFog_MovableLights when running with -d3ddebug
Fixed! UE-69310 Bloom_FFT rendering is cut off if viewport size is too wide
Fixed! UE-69104 [CrashReport] UE4Editor-MetalRHI!CreateMTLRenderPipeline() [MetalPipeline.cpp:696]
Fixed! UE-70833 Having textures active in paint mode and selecting a static mesh causes ensure and crash
Fixed! UE-70868 Editor crashes when attempting to use texture paint mode
Fixed! UE-70565 Editing material after changing Decal Blend Mode may cause editor to crash
Fixed! UE-70584 Wireframe Viewmode doesn't render during PIE
Fixed! UE-62797 [CrashReport] UE4Editor_UnrealEd!FLightmassProcessor::ImportLightMapData2DData() [lightmass.cpp:4385]
Fixed! UE-71114 Properly Fix Static Permutation Change Inside Editor
Fixed! UE-70607 SceneCapture2D output broken when used in VR
Fixed! UE-70681 Nan/INF on iOS when scene only contains objects with Movable mobility
Fixed! UE-71011 Assertion failed: RenderingThreadShaderMap when viewing Shader Complexity mode with new material
Fixed! UE-70493 Directional Light's intensity slider increments too many units to be useful
Fixed! UE-71275 Crash when canceling Compiling Missing Viewmode Shaders prompt - Assertion failed: !Material->RequiresSynchronousCompilation()
Fixed! UE-71297 [CrashReport] UE4Editor-Engine!FMaterial::GetShader(FMeshMaterialShaderType *,FVertexFactoryType *,bool) [MaterialShared.cpp:1913]
Fixed! UE-71282 [CrashReport] UE4Editor-RenderCore!FRDGBuilder::AllocateRHITextureUAVIfNeeded(FRDGTextureUAV const *,bool) [RenderGraphBuilder.cpp:584]
Fixed! UE-70591 Toggling the Shader Complexity viewmode requires missing viewmode shaders to be compiled
Fixed! UE-69206 Crash undoing Generating/Deleting Clusters
Fixed! UE-70413 Crash When Adding a Second Vector Parameter to Material Parameter Collection
Fixed! UE-67011 Clear coat materials seem to suffer from low bit depth issues
Fixed! UE-66953 Vulkan Crash in QAGame TM-DistanceFields
Fixed! UE-71298 [CrashReport] UE4Editor-D3D12RHI!SetRayTracingShaderResources<FD3D12RayTracingLocalResourceBinder> [D3D12RayTracing.cpp:1946]
Fixed! UE-71042 Landscape Far Shadows Interfere With Distance Field Soft Shadows
Fixed! UE-71314 Crash - Assertion failed: ColorVertexBuffer->IsInitialized() referencing LocalVertexFactory.h:93
Fixed! UE-71266 Missing Flying Vehicles for Highrise Map
Fixed! UE-71096 Decal stencil broken with partial prepass
Fixed! UE-71258 Disabling DBuffer Decals causes Decals not to render
Fixed! UE-70292 Static Mesh LOD Generation Produces Bad Shading and Holes in Mesh
Fixed! UE-68894 Deprecated Niagara Scripts are exposed to search
Fixed! UE-68750 Deprecated modules appear in the module search window
Fixed! UE-67445 Crash when creating New Niagara System with Default GPU system template
Fixed! UE-69803 Niagara collisions are overly-energetic in Content Examples
Fixed! UE-68811 Cascade update bug in SetMaterial
Fixed! UE-71353 Low FPS in Content Examples Niagara map with -vulkan
Fixed! UE-70965 Blotches appear over time in Path Tracing viewmode
Fixed! UE-71113 Ray traced reflection and translucency default roughness threshold does not match equivalent SSR threshold
Fixed! UE-71125 Material sorting shader dispatch size is computed incorrectly
Fixed! UE-71343 Respect shadow visibility when casting shadow rays
Fixed! UE-71339 Add shader permutation to support optional back-face culling in ray tracing SkyLight pass
Fixed! UE-69956 Crash occurs while simulating blueprint after triggering a breakpoint and clicking Step Over
Fixed! UE-71176 DirectX 12 missing from Targeted RHIs list
Fixed! UE-71028 Assertion failed: PlatformNeedsExtraDeletionLatency()
Fixed! UE-70773 GPU profiler is sometimes not consistent with GPU stats in D3D12
Fixed! UE-71094 Two "Auto Play" options listed in BP component ActorSequence details
Fixed! UE-71064 Sequencer does not Auto-key in VR Mode
Fixed! UE-71092 Restart option does not always restart the sequence
Fixed! UE-70355 Repeater events do not fire when the sequence is played in reverse
Fixed! UE-71151 Exporting an object from sequencer without left-clicking on it gives unwanted results
Fixed! UE-71130 Next Sequence value isn't updating in Sequence Recorder Window
Fixed! UE-71131 Field of View value doubles when selecting Add Key in sequencer window
Fixed! UE-71136 Sequencer Remove button is available without anything selected
Fixed! UE-71289 Crash rendering a 4k sequence with Use Separate Process disabled
Fixed! UE-71032 Crash evaluating a sequence with a geometry cache track in a packaged build
Fixed! UE-70298 Unable to choose which GeometryCache (Alembic) asset to Play for Geometry Cache track
Fixed! UE-71043 Take recorder doesn't check if the asset name is too long
Fixed! UE-71055 Split TakeSaveDir into 2 paths
Fixed! UE-70996 Crash when attempting to undo layer deletion referencing LevelTick.cpp:1032
Fixed! UE-69337 UDN have a material ID issue when generating LODs
Fixed! UE-71268 Crash Undoing and Redoing while Garbage Collection is Running
Fixed! UE-70950 Removing a Foliage Type from a ProceduralFoliageVolume does not remove the Foliage Type from the volume when it is resimulated
Fixed! UE-70564 IES loader crash the editor on reading file with only LF as line delimiter
Fixed! UE-58325 Large meshes now crashing on import
Fixed! UE-70675 Crash picking an LOD in the Skeletal Mesh editor after importing a new LOD
Fixed! UE-71267 when re-importing staticmesh, Auto-Generated LOD can have material slot swapped
Fixed! UE-71021 Making sublevel current, and using the add tool causes the editor to crash
Fixed! UE-71015 Copy/Paste tool in Landscape editor does not paste when performing Ctrl + V
Fixed! UE-70919 Crash after undo/redo spam within VRMode - referencing LevelTick.cpp Line:877
Fixed! UE-71026 Ensure from quickly scaling a landscape splines end tangent
Fixed! UE-71122 Landscapes with tessellation only produce shadows when selected
Fixed! UE-70972 Crash in Edit Mode after Static Mesh Proxy creation
Fixed! UE-70327 Editor crash when renaming actor sub-components in a multi-user session
Fixed! UE-71129 Error when leaving a multi-user session that contained a newly added asset with unsaved changes
Fixed! UE-70329 Renamed sub-component change not preserved
Fixed! UE-70396 Python CAD import do not create datasmith scene when running from commandline
Fixed! UE-63407 "Not a valid row name" message appears twice when renaming a data table row to none
Fixed! UE-71037 UMG elements added to another widget's named slot fail to compile
Fixed! UE-70912 Input Fields do not accept input from VR Mode Radial Number menus
Fixed! UE-70940 World Composition levels remain streamed in past their set streaming distance
Fixed! UE-70266 Virtual Production Utilities Plugin Missing Teleport Customization
Fixed! UE-71012 AJA - Option to output in 3Ga or 3Gb doesn't work
Fixed! UE-70351 VirtualProductionUtilities plugin - the BookmarkWidget asset cannot be nativized (converted to C++ at cook time)
Fixed! UE-66751 WMR native plugin trigger axis not working
Fixed! UE-70990 OculusAvatar Content has been saved with empty engine version
Fixed! UE-70994 Replace Oculus plugin binary with uninitialized memory fix.
Fixed! UE-70788 Couldn't find file for package MagicLeapHandTracking when launching to Windows
Fixed! UE-70907 VR Mode/Preview not available for Windows MR HMD in Binary
Fixed! UE-71110 Error when packing for Android using Oculus Avatar plugin.
Fixed! UE-70520 Oculus Avatar Plugin fails to package on Oculus Mobile
REMEMBER: Please report any new bugs you find by following the How To Report a Bug Guide
Und da kam auch schon die sechste Preview der UE 4.22 :D
Stephen Ellis;n1596822 schrieb:
UPDATE!
We have just released Preview 6 for 4.22! Thank you for your continued help in testing the 4.22 build before its official release. As a reminder, the Preview builds are for testing only, and should not be used for the active development of your project.
Fixed in Preview 6
Fixed! UE-71428 FLiveLinkMetaData::SceneTime is missing UPROPERTY markup
Fixed! UE-71631 Editor PIE Regression in //UE4/Main
Fixed! UE-71301 Ensure entering PIE when Anim Sharing state has no Anim Sequence
Fixed! UE-71300 Crash entering PIE when first Anim Sharing state is disabled - Assertion failed: (Index >= 0) & (Index < ArrayNum)
Fixed! UE-71303 Crash during PIE when two Anim Sharing states define the same state - Assertion failed: Components.IsValidIndex(PermutationIndex)
Fixed! UE-71492 ARPG Animation Issues With DefaultAnimCurveCompressionSettings Assets
Fixed! UE-71280 [CrashReport] UE4Editor-CryptoKeysOpenSSL!BN_num_bits [bn_lib.c:137]
Fixed! UE-71566 Editor can crash while performing a Hot Reload after a custom UClass class is added to the project
Fixed! UE-71556 Crash editing material asset Engine\Source\Runtime\Windows\D3D11RHI\Private\D3D11Commands.cpp] [Line: 1531]
Fixed! UE-71644 [CrashReporter] DataPrepEditors Crash - UE4Editor-DatasmithDataPrepLibraries!eea30000 + 194d8
Fixed! UE-71655 Datasmith Scene Reimport w/ Re-Spawn Deleted Actors fails and causes two Ensures - referencing SceneComponent.cpp Lines: 2125 & 1067
Fixed! UE-71480 Assertion failed in Datasmith Deltagen FBX importer
Fixed! UE-71265 MDL imported from Substance Source with Datasmith causes a crash
Fixed! UE-71253 Adding a new C++ Class puts Live Coding Console in a state (presumed crashed) where it cannot be resummoned
Fixed! UE-71501 Editor settings do not cause UBT makefile invalidation
Fixed! UE-71440 cl-filter fails to filter out including messages from Spanish Visual Studio version
Fixed! UE-71727 UBT errors generating project files when paths have ampersands in them
Fixed! UE-71319 Null access to Unpossessed controller with seamless travel
Fixed! UE-71677 GitHub 5629 : Typos in GameplayAbilitySystem
Fixed! UE-62491 [CrashReport] UE4Editor_Core!FName::InitInternal_FindOrAddNameEntry<char>() [unrealnames.cpp:818]
Fixed! UE-71690 Set from Euler (Quat)' and 'Set Components (Quat)' BP nodes have no output.
Fixed! UE-71575 Packaging Match3 with Nativization fails - error: unknown type name 'USoundWave'; did you mean 'USoundBase'? - Tile.h
Fixed! UE-71448 Mac: Building UE4 with a Space in the File Path Causes Copying Some DyLibs to Fail
Fixed! UE-71622 Mac crash when exiting QAGame with unsaved foliage painting
Fixed! UE-71414 View rect output can be incorrect with Android GLES.
Fixed! UE-71213 BlueprintOffice - Assertion Failed when interacting with button: MetalStateCache.cpp
Fixed! UE-70358 Failure to sign when packaging for iOS Distribution when using Remote Compile from a code project on Windows
Fixed! UE-71596 iOS packaging error with CloudKit enabled - Provisioning profile <...> doesn't match the entitlements file's values
Fixed! UE-70236 World flickers with World Origin Rebasing enabled
Fixed! UE-70189 iOS packaging does not reliably choose distribution vs development signing documents
Fixed! UE-68907 For Distribution packages fail: 'Unable to find mobile provision for UE4Game'
Fixed! UE-67863 Android 9 has api compatibility problem
Fixed! UE-64628 HTML5 Quick Launch fails to connect due to incorrect port
Fixed! UE-67484 tvOS LaunchOn error: IBCocoaTouchImageCatalogTool[7050:421228] CoreThemeDefinition: Unable to get image stack data for file
Fixed! UE-70766 iOS remote build unloads the Login Keychain on the remote Mac
Fixed! UE-71628 tvOS And iOS Binaries Not Being Created with Bitcode Enabled for Binary Builds
Fixed! UE-71397 Crash opening package with OpenGL4 referencing RenderingThread
Fixed! UE-71278 Shadow Bias rendering incorrect shadows in ContentExamples
Fixed! UE-71030 Frustum Culled Landscape Components Not Casting Shadows
Fixed! UE-70594 Debug viewmodes do not work in PIE until they have been enabled in level viewport
Fixed! UE-71589 IOS Mobile Forward Shading TM-Decals app crashes on launch, no member named 'read_write' in 'metal::access'
Fixed! UE-71309 Infiltrator Demo crashes referencing OpenGLShaders.cpp:3227 when running with OpenGL4
Fixed! UE-71643 [CrashReporter] UE4Editor-Engine!FMaterialRenderProxy::EvaluateUniformExpressions(FUniformExpressionCache &,FMaterialRenderContext const &,FRHICommandList *) [MaterialShared.cpp:2039]
Fixed! UE-71667 Crash opening MI_Foliage from within the static mesh editor
Fixed! UE-71561 Niagara systems with multiple light renderers process only the first one
Fixed! UE-71554 Certain materials are overly bright with Ray Traced Global Illumination denoiser
Fixed! UE-70796 Crash opening editor with raytracing: CmdListNumCommands == NumCommands
Fixed! UE-70888 Crash opening ArchVis sample with -d3ddebug
Fixed! UE-70782 Editor crashes loading IES Texture in DX12: Assertion failed: IsIESTextureFormatValid(LightProfileTexture)
Fixed! UE-70054 UE4 crashes when enabling RT translucency if the project has RT disabled
Fixed! UE-71454 ArchVis Raytracing mirror color is slightly brighter
Fixed! UE-71433 Vulkan One-Off Crash opening Physical Animation level - referencing BitArray.h Line: 723
Fixed! UE-71443 Vulkan RHI UE4Editor Crash when switching the transform gizmo to Rotate - referencing vulkancommands.cpp Line: 818
Fixed! UE-71386 Nans on Vulkan
Fixed! UE-71533 Engine Test Crash during initial launch running dx12 RHI on Nvidia GTX 960M - Referencing Shader.h Line: 1888
Fixed! UE-63264 Stat GPU graph not opening in -vulkan
Fixed! UE-71464 Cascading shadow maps behaving irregularly when utilizing Vulkan RHI
Fixed! UE-71438 UI for vector keys show wrong values
Fixed! UE-71174 Subway Sequencer audio stutters and cuts-out
Fixed! UE-71532 Spawn tracks aren't created for master sequence cameras
Fixed! UE-69411 Audio tracks in sequencer are not silent when extended past their playback end
Fixed! UE-71646 Sequencer applies values from one key to another on focus change
Fixed! UE-71222 Crash deleting assets - OutUniformExpressionCache.UniformBuffer->GetLayout() ...Engine\Private\Materials\MaterialShared.cpp] [Line: 2039]
Fixed! UE-71694 The "Orbit camera around selection" setting is not enabled by default
Fixed! UE-71447 Localization is failing to gather instanced container data correctly
Fixed! UE-71463 VRPresence Actor is using Vive controllers in VR Mode regardless of desktop VR Platform being used
Fixed! UE-71555 VRPresence hands need art adjustment for Oculus controllers
Fixed! UE-71007 nDisplay openGL crash with multi GPU
Fixed! UE-70993 Crash opening BP while in VRMode - Referencing SharedPointer.h Line: 849
Fixed! UE-71182 Media output does not work in PIE (New Editor Window)
Fixed! UE-71010 AJA - burned timecode doesn't always matches between UE and AJA
Fixed! UE-71390 Binary Editor fails to start with Windows Mixed Reality enabled on win10 version < 1803
Fixed! UE-71425 Error occurs when packaging with Oculus Avatar plugin due to missing xml file.
Fixed! UE-71277 Landscape z-fighting in TM-VRSmoke on Oculus
Fixed! UE-70953 Landscape components artifacting in peripheral vision of the Oculus HMD
Fixed! UE-71597 Windows Mixed Reality rendering problems on Win 10 Release 1803
Fixed! UE-71637 WMR - Editor hang on when exiting PIE
Fixed! UE-71558 Failing to load Windows Mixed Reality Interop Library when enabling the WMR plugin while on valid Windows versions
Fixed! UE-69820 Motion Controller meshes do not track with Motion Controller position within VRMode
Fixed! UE-67297 ShaderCompiler crash when opening the editor with Morpheus plugin and project setting enabled
Fixed! UE-65414 ARCore - Rotating app during bootup cause scaling issues on startup
Fixed! UE-71625 Failing to load Windows Mixed Reality Interop Library when launching onto or running a package on Windows
Fixed! UE-71654 WMR shouldn't be loading things from that AppLocalDependencies folder
Und da ist auch schon die siebte Preview der UE 4.22 :P
VictorLerp;n1599208 schrieb:
UPDATE!
We have just released Preview 7 for 4.22! Thank you for your continued help in testing the 4.22 build before its official release. As a reminder, the Preview builds are for testing only, and should not be used for the active development of your project.
Fixed in Preview 7
Fixed! UE-71623 QAGame's Automatic Projectile Gun audio is stacking on iOS
Fixed! UE-71377 UE pak encryption improvements
Fixed! UE-71803 Blueprint Template project with Pak Signing enabled but no key fails to build
Fixed! UE-71806 No warning printed when Pak Encryption is enabled but no Signing Keys are Generated
Fixed! UE-71811 .sig file is generated for an "unsigned" platform and application fails to open
Fixed! UE-71769 Terminated editor sessions are not tracked correctly
Fixed! UE-62612 Editor crashes after creating a C++ Derived Class and reopening the project
Fixed! UE-71581 Warning after hot reload: Engine class 'QAUnrealEdEngine' has changed but will be ignored for hot reload
Fixed! UE-71880 The engine crashes trying to load assets saved with a newer engine version
Fixed! UE-71812 Crash reimporting when Datasmith Scene actors is none
Fixed! UE-71788 Load Scene button should be ghosted when there is no file set in the scene settings
Fixed! UE-71553 Crash importing FBX using the Deltagen importer with Merge Nodes enabled - Assertion failed: PolygonNormals.IsValid()
Fixed! UE-71692 Mac: Hot Reload with bundle resource fails with 'Error: Hot-reloadable files are expected to contain a hyphen'
Fixed! UE-71564 Widget Blueprints not Functioning in Packages with Inclusive Nativization
Fixed! UE-71567 Crash attempting to open another level while diffing the current level's blueprint
Fixed! UE-71665 [CrashReport] UE4Editor-Kismet!SSCSEditor::AddNewComponent(UClass *,UObject *,bool,bool) [SSCSEditor.cpp:5121]
Fixed! UE-71724 Packaging for Linux with ARM64 Enabled Fails to Build For Use of Undeclared Identifiers
Fixed! UE-60685 GitHub 4805 : EnableSnapshots for GooglePlay
Fixed! UE-71891 Editor crash on switching to mobile preview
Fixed! UE-61585 A big and sharp spotlight's shadow can flicker
Fixed! UE-71826 Lighting is creating Inconsistent shadows in PIE
Fixed! UE-71781 Pre-Exposure does not work
Fixed! UE-71731 Random Game Crash in FMeshDrawCommand::SubmitDraw()
Fixed! UE-71568 Crash: Unhandled exception UE4Editor_Renderer!FMobileBasePassMeshProcessor::Process
Fixed! UE-71928 LocalVF assert when opening content examples in iOS preview mode
Fixed! UE-71887 Crash running DX12 package of Infiltrator Demo - Assertion Failed FPlatformProperties::RequiresCookedData
Fixed! UE-71868 Localized pin names can break Niagara graphs
Fixed! UE-71810 Crash when launching dx12 for the first time with Rect Lights
Fixed! UE-71579 Crash editing material instance parameters
Fixed! UE-71768 Old widget animation events not firing
Fixed! UE-71375 EngineTest: Crash UE4Editor-InputBindingEditor.dll!FInputBindingEditorPanel::Tick() - sinputbindingeditorpanel.cpp:39]
Fixed! UE-71689 Translating with Camera lags when Use Distance-Scaled Camera Speed is true
Fixed! UE-71374 Crash closing the import prompt after previously importing an LOD from a new file - Pure virtual function being called
Fixed! UE-70335 Importing through Python fails
Fixed! UE-71889 Imported Hierarchies are inverted with Create Import Hierarchy
Fixed! UE-71618 Portuguese and Spanish editor languages do not display localized text
Fixed! UE-71747 Transaction Included and Excluded Class Filters are not applied in Binary builds
Fixed! UE-71715 Crash when a client undoes deleting a landscape during a Multi-User session
Fixed! UE-71718 Crash when a client hides/unhides a sublevel in the Levels window during a Multi-User session
Fixed! UE-71756 Crash on new level after executing python command unreal.EditorLevelLibrary.spawn_actor_from_object - UE4Editor_Core!FWindowsErrorOutputDevice::Serialize() [engine\source\runtime\core\private\windows\windowserroroutputdevice.cpp:79]
Fixed! UE-66681 Child Widget Blueprint does not inherit bindings in exe
Fixed! UE-70946 Cameras in VR Mode over oversized
Fixed! UE-71796 Assert undoing dragging a Camera from the Modes Panel into the level from VR Mode
Fixed! UE-70909 Windows MR crashes when selecting VR Mode
Fixed! UE-67737 WMR: Crash in VR Edit Mode
Fixed! UE-71871 Prevent Windows Mixed Reality from using VR Mode
Fixed! UE-71573 Crash starting VRMode on a Windows Mixed Reality headset
Fixed! UE-71645 Remove Windows Mixed Reality binaries from InstalledEngineFilters.xml
Heute wurde dann, nach ganzen sieben Previews, die UE 4.22 endlich released. Dabei sind ein überarbeiteter Renderer, Unterstützung für Visual Studio 2019 und ein integrierter Ray- und Path-Tracer. Da das Changelog wie üblich zu lang ist, hier der Link: Unreal Engine 4.22 Released!
