CORSAIR_Marcus
Corsair Staff
Patch notes for iCUE version 4.18.209
You can download the iCUE installer by going to our iCUE software page and clicking DOWNLOAD NOW.
Software Enhancements
- Checking the ‘Delete all saved settings’ checkbox will now properly delete all files during
- uninstallation
- CPUID SDK has been updated for the latest generation of Intel CPUs
- All tooltip descriptions have been visually improved
- Devices that undergo the force update process will no longer disappear from iCUE
- Device image scrolling is no longer obstructed by device images
- Resolved several issues with overlapping messages and disappearing pop-up windows
- Keyboards and mice will no longer disconnect if audio is playing during the installation of iCUE
- Selecting keyboard layouts no longer results in the wrong device image being displayed
- Resolved an issue with the tilt panel for gestures that occurs after closing the Device Settings tab
- Sabre PRO series mice will no longer have X/Y DPI unlinked by default
- Resolved an issue with SCIMITAR RGB ELITE’s front zone lighting not playing the correct lighting
- effect
- K100 Control Wheel’s macOS toggle for track jogging and zoom will now be saved properly when
- toggled
- H55/100/150 RGB’s analog pump cap lighting is now supported on Commander Core XT
- Commander Core XT will no longer default to the setup tab after device selection
- Selecting the number of 8-LED Fans is no longer segregated by device type
- Opacity for Vengeance LED now works correctly when configuring lighting effects that use it
- Resolved an issue with Elite LCD’s label colors being affected by certain sensors
- Elite LCD will now display a notification to confirm the deletion of images and gifs that are assigned
- to different profiles
- Elite LCD now supports 3 new patterns: Dual Bar, Turbo, and Clock
- Resolved an issue with LS100 device images not scaling properly during window resizing
- DDR5 now properly shows frequency and timings on the Dashboard
