Release Notes for iCUE 4.23.137
CORSAIR_Marcus
Corsair Staff
Hier könnt ihr die aktuellen Release Notes von iCUE einsehen inkl. download.
Software Enhancements​
  • The following legacy products are now supported:
  1. KATAR RGB
  2. SCIMITAR RGB
  • Mic Boost option is now available for all iCUE supported headsets – to increase the gain on your microphone, go to the device settings and adjust the slider for ‘Mic Boost’ to your preference
  • Audio driver has been updated – this will require a system restart after iCUE finishes the installation process
  • Notifications have been added for the successful importing and exporting of profiles
HID Product Enhancements​
  • K65 MINI macros that are configured for trigger on release will properly work for key combinations with the FN and FN2 keys
  • Quick Lighting Zones now have a 255 character limit to avoid text runoff issues
  • For devices in multipoint mode (2:1 or 3:1), there is now a 10ms delay between character inputs for Text actions – this was to resolve characters missing or registering inaccurately when the action is
  • triggered
  • SABRE PRO and SABRE PRO RGB will now properly report the last DPI stage the device was using to iCUE instead of always defaulting back to DPI stage 1
DIY Product Enhancements​
  • Variable Speed for pumps is now available as a pump speed option for Hydro Series ELITE coolers
  • Resolved a graphical issue with the sixth fan tile when using the wizard with Commander Core
