mAlkAv
PCGHX-HWbot-Member (m/w)
431L sounds good. Ok you need a 10k VR for this probably. Please check the resistance between the lower left pin and ground.
Here's the datasheet: 431L pdf, 431L description, 431L datasheets, 431L view ::: ALLDATASHEET :::
The reference Pin is the one which needs to be modified.
