Was sagt mir dieser Benchmark und sind die Einstellungen passend dadazu?
Phipz87
ich bin nicht so der Profi was Einstellungen angeht und weiß auch nicht was mir dieser Benchmark wirklich bringt... Ich habe Ihn eben laufen lassen und eigentlich stand immer FPS 60 kurzmal bei Tageslicht wechsel ging es auf so FPS 55 runter aber danach wieder sofort FPS 60
Hier das Benchmark-Test Ergebnis:
Code:
 Frames Per Second (Higher is better) Min, Max, Avg
Pass 0, 16.714821, 61.616611, 59.919434
Pass 1, 31.382122, 67.701118, 56.789974
Pass 2, 44.777439, 73.457253, 59.759518
Pass 3, 35.725231, 66.058556, 59.960190
Pass 4, 22.228655, 82.989532, 59.423565
Time in milliseconds(ms). (Lower is better). Min, Max, Avg
Pass 0, 16.229389, 59.827145, 16.689075
Pass 1, 14.770804, 31.865276, 17.608742
Pass 2, 13.613359, 22.332676, 16.733736
Pass 3, 15.138084, 27.991421, 16.677732
Pass 4, 12.049712, 44.986977, 16.828341
Frames under 16ms (for 60fps):
Pass 0: 0/565 frames (0.00%)
Pass 1: 1/533 frames (0.19%)
Pass 2: 5/565 frames (0.88%)
Pass 3: 1/567 frames (0.18%)
Pass 4: 45/7018 frames (0.64%)
Frames under 33ms (for 30fps):
Pass 0: 564/565 frames (99.82%)
Pass 1: 533/533 frames (100.00%)
Pass 2: 565/565 frames (100.00%)
Pass 3: 567/567 frames (100.00%)
Pass 4: 7017/7018 frames (99.99%)
Percentiles in ms for pass 0
50%,	16.00
75%,	16.00
80%,	16.00
85%,	16.00
90%,	16.00
91%,	16.00
92%,	16.00
93%,	16.00
94%,	16.00
95%,	16.00
96%,	16.00
97%,	16.00
98%,	16.00
99%,	17.00
Percentiles in ms for pass 1
50%,	16.00
75%,	18.00
80%,	18.00
85%,	19.00
90%,	20.00
91%,	20.00
92%,	20.00
93%,	20.00
94%,	21.00
95%,	21.00
96%,	21.00
97%,	22.00
98%,	23.00
99%,	24.00
Percentiles in ms for pass 2
50%,	16.00
75%,	16.00
80%,	16.00
85%,	16.00
90%,	16.00
91%,	16.00
92%,	16.00
93%,	17.00
94%,	17.00
95%,	17.00
96%,	17.00
97%,	17.00
98%,	18.00
99%,	18.00
Percentiles in ms for pass 3
50%,	16.00
75%,	16.00
80%,	16.00
85%,	16.00
90%,	16.00
91%,	16.00
92%,	16.00
93%,	16.00
94%,	16.00
95%,	16.00
96%,	16.00
97%,	16.00
98%,	16.00
99%,	16.00
Percentiles in ms for pass 4
50%,	16.00
75%,	16.00
80%,	16.00
85%,	17.00
90%,	17.00
91%,	17.00
92%,	17.00
93%,	17.00
94%,	17.00
95%,	17.00
96%,	17.00
97%,	18.00
98%,	19.00
99%,	21.00
=== SYSTEM ===
Windows 7 Professional 64-bit (6.1, Build 7601)
DX Feature Level: 11.0
Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz (4 CPUs), ~3.5GHz
8192MB RAM
AMD Radeon R9 200 Series (AMD Radeon R9 280X || AMD Radeon HD 7900 Series), 3199MB, Driver Version 14.502.1014.0
Graphics Card Vendor Id 0x1002 with Device ID 0x6798
=== SETTINGS ===
Display: 1920x1080 (FullScreen) @ 60Hz VSync ON
Tessellation: 3
LodScale: 1.000000
PedLodBias: 0.200000
VehicleLodBias: 0.000000
ShadowQuality: 3
ReflectionQuality: 2
ReflectionMSAA: 4
SSAO: 2
AnisotropicFiltering: 4
MSAA: 0
MSAAFragments: 0
MSAAQuality: 0
TextureQuality: 2
ParticleQuality: 2
WaterQuality: 2
GrassQuality: 3
ShaderQuality: 2
Shadow_SoftShadows: 1
UltraShadows_Enabled: false
Shadow_ParticleShadows: true
Shadow_Distance: 1.000000
Shadow_LongShadows: false
Shadow_SplitZStart: 0.930000
Shadow_SplitZEnd: 0.890000
Shadow_aircraftExpWeight: 0.990000
Shadow_DisableScreenSizeCheck: false
Reflection_MipBlur: true
FXAA_Enabled: true
TXAA_Enabled: false
Lighting_FogVolumes: true
Shader_SSA: true
DX_Version: 2
CityDensity: 1.000000
PedVarietyMultiplier: 1.000000
VehicleVarietyMultiplier: 1.000000
PostFX: 3
DoF: true
HdStreamingInFlight: false
MaxLodScale: 0.000000
MotionBlurStrength: 0.000000
Hier meine Einstellungen Ingame:
Was komisch ist, sobald ich dieses MSAA auf z.b X2 oder mehr stelle, habe ich rechts unten im Bild solche Pixel:
Danke für Hilfe im Voraus :)
ja das habe ich ja auch gesehen....
meine frage speziell jetzt, lieber etwas mehr grafik hoch drehen um vllt von 60 fps auf 50 fps runter zu kommen oder lieber so lassen?
Wenn du ein noch schöneres Bild haben willst mache FXAA aus und MSAA auf 2 oder 4x.
Dazu Vsync aus den Antiosotopischer Filter x16 und die Reflextion MSAA ebenso auf aus.
Gras nicht über die Einstellung hoch außerhalb der Stadt wird so die FPS stark sinken.
Weiche Schatten auf AMD.
Stell mal "Nachbearbeitung" auf hoch, dann sollte der Bug weg sein. Dann kannste auch wieder MSAA dazuschalten
