Sammelthread RaceRoom Racing Experience
Sammelthread
Ich blick irgendwie nicht durch. Das Spiel ist gerade in der Open-Beta und noch nicht released, oder?
Weiß man schon was über den Termin?
lg
R3E -> Q&A Response Part 1
http://insider.simbin.com/r3e-qa-response-part-1/
R3E -> under maintenance today | Simbin Insider
R3E is under maintenance today as we are performing game updates. Below you can read what is included in the update:
Game & Code
Added Wrecker prevention. This is mainly for upcoming features but also works in Track Test. Player car will be ghosted when it resets, when it drives the wrong way and similar scenarios.
Fixed an issue with downloading own ghosts if local ghost file had been deleted.
Fixed ghost trying to download and fail when starting a competition you already have an entry in.
Fixed Expert Apex hunt completion screen skipping.
Improved the logging functionality to provide us more information on certain errors (e.g. error code 2).
Fixed smoke render making the car edges look pixelated on some systems.
Fixed a DirectX particle related issue that could cause a crash on some systems.
Fixed an issue where maintenance mode messaging wasn’t handled graciously if the player was in the game when the maintenance mode was activated.
Fixed a crash that could occur when entering a track after leaving another track.
Fixed fast motion blur appearing corrupt on some occasion.
Fixed complex motion blur not working in cockpit mode.
Updated default controller profile for Thrustmaster F430 FFB. FFB Rumble and speed sensitive steering set to 0.
Fixed a distance issue with tire mark generation.
Alpina is now called BMW Alpina.
Updated copyright info on executable details.
Renamed our executables to RRRE to help with issues some 3rd party programs were having. Unfortunately, your 3rd party program might also need an update to support the change.
Fixed an issue with sound manager in code that could cause a rare crash.
Fixed some hud strings appearing unlocalized in replay.
Fixed an issue when using an assigned clutch button, the values for clutch sensitivity and steering sensitivity would become synchronous.
Fixed a crash that could occur when changing video settings on some systems.
Improved overall environment shadows.
Shadow split is now ON by default in medium preset in video settings.
Fixed confirm button string in Spanish on buy popups.
Optimized loading times.
Fixed an issue with first replay file not getting a number and ending up showing in wrong order.
Fixed a memory leak after game initialization.
Prepared the build for future content releases.
Portal
Implemented discount functionality.
Fixed an issue where users were getting “Server connection timeout” issues for a long time.
Fixed an issue where position bar wasn’t getting filled with other entries, when doing a class based LBC in novice mode.
Fixed an issue where top banners in store page were sometimes not appearing correctly.
Fixed an issue where player LB entry was not centered in the table.
Fixed jump to my position not functioning correctly.
Fixed an inconsistency between the LB position number in in-game position bar and LB entry in the LB table.
Fixed gPos showing the same position as the filtered position when filtering a LB.
Fixed an issue where you could get multiple entries of a car in a LB.
Fixed an issue where friends LB entries weren’t showing in the bar above the LB table.
Added a friendlier internal server error page.
Added a user friendly page for users getting currency mismatch error.
Added a user friendly error message for transaction failures.
Fixed an issue where some users were having currency mismatch issues when trying to purchase VRP’s.
Added Discounted items page to the store. (Won’t be visible until there are discounts)
Added purchased items store page
Added recent content store page and set it as main page in the store
Added most popular content store page
Added ability to see individual liveries in large screenshots when magnifying.
Fixed functions like search and login not working on websites set as widget in dashboard.
Added option to change the currency for purchasing VRP.
Art
Tweaked Raceroom Hillclimb shadows
Fixed minor issues on lamp posts, fixed structures and some trees not casting shadows in Monza.
Adjusted/tweaked the particles for all cars for better ambient lighting.
Improved collision shape for all cars.
Sieht echt lecker aus. Ich liebe dieses Auto. Hab schon eine M1 Mod für Race 07. Für R3E werd ich wohl auch die paar EUR investieren müssen. :love:
Danke, da muss man glatt mal wieder reinschauen.
Übrigens, zu dem seltsamen Problem mit dem Savegame hab ich keine zufriedenstellende Antwort vom Support bekommen.
Mit Admin-Rechten kann man das Ganze umgehen, was für mich aber sehr umständlich ist, da (fast) alle meine Spiele ohne Admin-Rechte laufen.
Die Antwort war sinngemäß, dass das Problem bekannt sei, aber man noch keine Lösung in Aussicht hat.
Schade, hoffentlich wird das noch was.
Aber ist ja noch Beta...
@ak1504
Erstaunlich, dass das an dir vorüberging.
Es besteht seit dem großen Juli-Update bei vielen das Problem, dass die Savegame-Daten vom Spiel ignoriert werden und einfach ein neuer Save-Ordner erstellt wird.
Seltsamerweise passiert das nicht immer.
Als Workaround kann man Steam und damit auch R3E als Admin ausführen.
Ganz tolle Lösung. :schief:
Ich habe über 50 alte und neue Spiele in meiner Sammlung, die klaglos ohne Admin-Rechte laufen. Kann doch also nicht so schwer sein.
Du meinst deine Einstellungen die du ingame machst mit Savegame..?
Und den Ordner unter Dokumente/Meine Spiele/Simbin usw..?
Der wird jedes mal neu erstellt..?
