DirectX 11 und 10 läuft nicht mit GTX 570
SubSiRo
Dieser Fehler wird bsp. weiße bei dem Heaven Bench unter DX 10 und DX 10 angezeigt, DX 9 läuft ohne Probleme.
D3D11 AppWindow::swap window(): device removed
Bei WOW unter DX 11 kommt diese Fehler Meldung nur unter DX 9 wiederum garnichts.
World of WarCraft: Retail Build (build 14007)
Exe: C:\Program Files (x86)\World of Warcraft\WoW.exe
Time: May 14, 2011 4:25:24.926 PM
User: SiRo-CoOl
Computer: SION
This application has encountered a critical error:
Fatal exception!
Program: C:\Program Files (x86)\World of Warcraft\WoW.exe
ProcessID: 7356
Exception: 0xC0000005 (ACCESS_VIOLATION) at 0023:01659F33
The instruction at "0x01659F33" referenced memory at "0x00000004".
The memory could not be "read".
WoWBuild: 14007
Version: 4.1.0
Type: WoW
Realm: Perenolde (195.12.241.15:3724)
Local Zone: Höllschreis Griff, Halbinsel von Tol Barad
Local Player: Subsiro, 028000000190D3BE, (-584.006,1401.16,21.3796)
Total lua memory: 49171KB
Current Addon: (null)
Current Addon function: UNKNOWN
Current Addon object: (null)
Add Ons: Atlas Atlas_OutdoorRaids Atlas_Transportation Atlas_DungeonLocs Atlas_Battlegrounds AtlasLoot_Loader BalancePowerTracker !BugGrabber BugSack Gatherer Ace3 Omen OneBag3 OneBank3 GearScore Postal Prat-3.0 Prat-3.0_Libraries Quartz Quartz_Procs QuestHelper Recount Reforgenator SexyMap SexyMapTrackerButtonFix SlideBar XPerl XPerl_ArcaneBar XPerl_PlayerBuffs XPerl_Player XPerl_Target DBM-Core DBM-BurningCrusade
Settings:
SET locale "deDE"
SET coresDetected "1"
SET hwDetect "0"
SET gxMultisampleQuality "0.000000"
SET videoOptionsVersion "4"
SET movie "1"
SET Gamma "1.000000"
SET showToolsUI "1"
SET Sound_OutputDriverName "System Default"
SET Sound_MusicVolume "0.20000000298023"
SET Sound_AmbienceVolume "0.60000002384186"
SET farclip "1250"
SET specular "1"
SET gxResolution "1920x1080"
SET mouseSpeed "1"
SET readTOS "1"
SET readEULA "1"
SET readTerminationWithoutNotice "1"
SET readScanning "1"
SET accounttype "CT"
SET VoiceActivationSensitivity "0.39999997615814"
SET ChatMusicVolume "0.29999998211861"
SET ChatSoundVolume "0.39999997615814"
SET ChatAmbienceVolume "0.29999998211861"
SET gameTip "114"
SET readContest "-1"
SET installType "Retail"
SET Sound_EnableHardware "1"
SET realmName "Perenolde"
SET textureFilteringMode "5"
SET gxRefresh "60"
SET showItemLevel "1"
SET ShowAllSpellRanks "0"
SET equipmentManager "1"
SET questLogCollapseFilter "-1"
SET previewTalents "1"
SET shadowLevel "0"
SET enterWorld "1"
SET useUiScale "1"
SET DesktopGamma "1"
SET environmentDetail "150"
SET uiScale "0.84999996423721"
SET waterDetail "3"
SET maxFPS "70"
SET Sound_NumChannels "32"
SET gxMultisample "8"
SET graphicsQuality "5"
SET componentTextureLevel "9"
SET terrainMipLevel "0"
SET sunShafts "2"
SET groundEffectDensity "128"
SET groundEffectDist "260"
SET projectedTextures "1"
SET shadowMode "3"
SET shadowTextureSize "2048"
SET Sound_OutputQuality "2"
SET playIntroMovie "4"
SET checkAddonVersion "0"
SET Sound_MasterVolume "1"
SET gxApi "D3D11"
SET weatherDensity "3"
GxInfo
GxApi: D3D11
Shader Model: 5_0
Vertex: vs_5_0
Hull: hs_5_0
Domain: ds_5_0
Geometry: gs_5_0
Pixel: ps_5_0
Compute: cs_5_0
x86 Registers
EAX=00000000 EBX=058720B8 ECX=66818506 EDX=00000000 ESI=058720B8
EDI=19D406C8 EBP=0020F2E8 ESP=0020F2DC EIP=01659F33 FLG=00010202
CS =0023 DS =002B ES =002B SS =002B FS =0053 GS =002B
.....Was ihr den Rest von der Fehlermeldung von WOW benötigt kann ich das dann noch posten.
Was kann ich noch testen?
Woran können diese Fehler liegen?
Rechner stürtz ja nie ab nur die Anwendung bei DX 11.
Der Rechner ist ganz neu:
Windows 7 64-Bit
Rest siehe Signatur
AW: DirectX 11 und 10 läuft nicht mit GTX 570
Also die Fehlermeldung bzw das hier "D3D11 AppWindow::swap window(): device removed" sagt aus, dass die Karte kurz nicht mehr erkannt wird, kann es sein, dass kurz nachdem der Fehler auftritt Windows angibt, dass der Treiber wiederhergestellt wurde?
Das würde nämlich erklären, warum die Karte kurzzeitig nicht mehr erkannt wird.
Wenn das der Fall ist, dann ist sie wohl instabil und du solltest sie umtauschen, wenn das noch geht
Das Prob tritt bei Gigabyte 560er/570ern gerne auf, vor allem bei den OC-Karten. Ich würde auch empfehlen die Karte zur Garantie einzuschicken oder sie umzutauschen.
Hi, also das mit dem Treiber wiederherstellen kommt nicht.
Ich lande einfach wieder im Windows mit einer Fehlermeldung.
Hatte bis jetzt noch keinen Absturz!
Warum hab ich eigentlich immer so ein Pech mit Nvidia Grafikkarten? ^^ Die von ATI liefen bis jetzt immer Anstandslos!
Naja hatte davor erst eine Nvidia DX 8 Karte ^^
Gibts bei Win7 64-Bit eigentlich noch irgendetwas zu beachten in zusammenhang mit Spielen und Grafiktreibern?
Hatte davor WinXP mit Athlon XP also alles so ungewohnt noch! ^^
Eventuell kannst du mal versuchen das Systemschema auf "Basic" zu stellen das hat auch schonmal funktioniert.
haste ma das dx-update gemacht?also manuell die exe gezogen und durchlaufen lassen?!
was sagt dein dxdiag?
Lad dir mal MSI Afterburner: Download
Schau nach, welche Spannung anliegt. Und stell die mal auf 0.988V, oder 1.000V~
Alternativ kannst du auch den Takt verringern~
Oder eben ein Offizielles Bios-update auf die Graka spielen, dabei wär die Spannung aber 1.038V oder so, daher läuft meine Gigabyte GTX 570 auf:
750mhz
1500 mhz
2000 mhz
0.975 Volt (Bios in eigenregie geflasht)
750mhz
1500 mhz
2000 mhz
Naja da würd ich sie lieber in die RMA geben, wenn sie nicht stabil ist, als da selbst dran rumzuflashen um sie stabil zu bekommen^^
Würde ich auch in die RMA schicken.
Ein Produkt hat zumindest den Angaben entsprechend zu laufen, dafür hat der Hersteller zu sorgen, nicht der Kunde.
Ist mir jetzt aber schon öfter bei Gigabyte Karten zu Ohren gekommen :what:
Dafür hat gigabyte doch extra ein angepasstes Bios, welches man auf der gigayte homepage runterladen kann, und Ohne garantieverlust flashen kann.
Ehrlich gesagt, nur für sowas lächerliches wär mir der Aufwand fürne RMA nicht wert, wenn ich das Problem in wenigen Minuten selbst lösen kann :P
(liegt vll daran, dass ich nen Monat davor ne Phantom hatte, die nen völlig defekten Kühler hatte, und deswegen zurück musste, und ich keine Lust hatte wieder zurück zu schicken, wenn die karte nicht physikalisch defekt ist)
Rein vom Prinzip kann ichs aber natürlich verstehen, dass man auf RMA besteht.
