Asus MG279Q: Freesync-LCD mit 1440p, IPS und 90/144 Hz verfügbar
Jetzt ist Ihre Meinung gefragt zu Asus MG279Q: Freesync-LCD mit 1440p, IPS und 90/144 Hz verfügbar
Sowohl Asus-USA als auch Asus-Deutschland haben in Pressemitteilung die sofortige Verfügbarkeit des MG279Q bekanntgegeben. Hierzulande hat sich offenbar Alternate die ersten Chargen gesichert, dort ist der Monitor derzeit als einziges für die empfohlenen 650 Euro verfügbar. Derweil gibt es noch Ungereimtheiten bei der maximalen Bildwiederholrate mit Freesync.
Zurück zum Artikel: Asus MG279Q: Freesync-LCD mit 1440p, IPS und 90/144 Hz verfügbar
AW: Asus MG279Q: Freesync-LCD mit 1440p, IPS und 90/144 Hz verfügbar
Hier mal ein neuerer Kommentar vom AMD Rep im OCUK Forum zur 90/144hz Thematik:
I've been working on getting you all some better information about the MG279Q and the FreeSync range, and I've had quite a productive conversation this morning.
So, owing to engineering limitations it's not possible to provide FreeSync across the full range of frequencies (as you may have read about), and that's something that all manufacturers are working with. What we determined in testing, and indeed in discussion with AMD, was that the lower boundary was key - with that lower boundary too high, if your fps dropped, you would lose FreeSync capabilities and notice the impact. Therefore, we decided to set the lower boundary at 35 Hz and that required us to bring the higher boundary down to 90 Hz. In testing, the effects of no FreeSync at 35-40 Hz were much more pronounced than they were >90 Hz so this made sense.
On the whole, whilst I can understand that a few might be disappointed, it should provide a great balance of the colour reproduction you expect with IPS, plus tear-free gaming at up to 90 fps / Hz - and you'll likely benefit far more from the lower minimum bound than you would from a higher maximum bound, given that it's effectively a choice between the two.
Hopefully that all makes sense!
Irgentwie ein wenig entäuschend, die erste Generation der neuen Scaler scheint wohl doch noch nicht so ausgereift zu sein. Bei einem 144hz Monitor wäre es mir außerdem lieber gewesen wenn sie den Bereich von 40-144hz genommen hätten statt 35-90hz. Ich hoffe, dass es nicht zu lange dauern wird bis man da mit GSync auf einem Level ist, also einen Funktionsbereich von 30-144hz abdecken zu können. Schade, dass sie nicht lieber mit dem Release des gesamten Adaptive Sync Ökosystems gewarten haben, bis man da auf einem Niveau mit GSync ist, so wirkt das ganze doch irgentwie überhastet und halbherzig.
Womöglich könnte (Achtung: Konjunktiv II) ein kommendes Firmware-Update nachhelfen.
Dann werde ich das mal abwarten, und solange den Monitor im Hinterkopf behalten.
Habe ihn seit heute und was soll ich sagen? Ich find die Größe echt toll, das Bild ist sehr scharf und die Farben sind toll. Ich habe ihn auf 120fps limitiert, da ich dort das Bild seltsamerweise flüssiger empfinde als mit 144fps.
Der einzige Haken, den ich befürchtet hatte, hat sich bewahrheitet. Das Panel leidet im unteren linken und rechten Eck unter unschönem Backlight-Bleeding. Das Bild ist dort fast immer als relativ dunkles Grau zu vernehmen. Schade, also geht er zurück und wird umgetauscht. Ich hoffe nur, dass ich vielleicht einen erwische, bei dem es nicht auftritt. Frage mich nur wie wahrscheinlich das ist.
Sehe ich nicht so. Die allermeisten Monitore sind sowieso 60Hz limitiert, für diese funktioniert Freesync super. Es ist halt kein schlauer Schachzug von Asus einen 144Hz "Freesync" Monitor rauszubringen, obwohl sie noch keinen vernünftigen Scaler dafür haben. Dafür alle anderen Monitore zurückzuhalten wäre aber Quatsch.
Habe den Monitor jetzt seit ende April im Einsatz und bis auf das IPS bedingte BLB + Glow ist alles top. Habe ich ja in meinem Thread aber alles schon geschrieben.
Lies dir mal Post 43 durch! Darum findest du wohl 120 Hertz besser :/
http://extreme.pcgameshardware.de/monitore/387168-gerade-den-mg279q-bekommen-5.html
Wobei man das bei einer Limitierung der fps nicht bemerkt, sondern nur wenn man die Hertz auf 120 setzt.
Ich finde es relativ enttäuschend was der MG279Q abliefert.
Freesync nicht voll nutzbar, BLB, Probleme bei 144Hz.
Gut, dann schicke ich ihn zurück und bestelle ihn in ein bis zwei Monaten nochmal. Schade, hätte gerne The Witcher 3 darauf gespielt.
Laut schwedischen Forum, kann der MG279Q überhaupt keine 144Hz,
man kann ihn zwar darauf einstellen, aber gibt nur 120fps raus, verschluckt jedes 6. frame.
Es soll ein Auslieferungsstop geben und die schon verschickten soll man wegen firmenware update zurück senden.
Ok das ist mir ernsthaft noch nicht aufgefallen... also zurück damit :/
Wird dann wohl doch eher ein anderer Monitor, da ich dann garantiert einen mit schlimmerem BLB bekomme...
Naja, bei WQHD mit 144Hz hast du ja mittlerweile etwas Auswahl.
Und wieder nicht ausgereifte Technik auf dem Markt.
Tatsache mit 120hz ist er nochmal einen zwacken flüssiger... Gut ASUS wie bekomme ich jetzt für die nächsten Tage nen Monitor ? :schief:
Das erklärt mir auch warum Freesync@90hz besser war als 144hz+Vsync
Du machst bei 144Hz Vsync an?
Willst du den gleichen Monitor wieder haben, dann lass ihn direkt von Asus tauschen.
Ne das war nur zum Testen, wie sich das ganze anfühlt ;)
Die anfrage an Asus was ich mit der Mühle machen soll ist schon raus, mal gucken was da kommt. Ich würde gegen einen direkten Tausch nichts einwenden.
Aber wehe dem der Austauschmonitor hat nen Pixelfehler oder extremstes BLB dann gibt es was auf die Ohren :motz:
Normalerweise sollten die dir sagen, dass du den direkt von Asus vor Ort tauschen lassen sollst.
Mal ganz ehrlich wo sind wir denn wenn man für Firmware-Updates das Ding zu ASUS geben muss :what:
^ This.
Schade eigentlich, wäre ein Kandidat für mich gewesen. Zum Glück habe ich ihn schon vorher wegen dem Backlight-Bleeding von meiner Liste gestrichen. Macht scheinbar nur Probleme das Ding.
