Asrock B850 Livemixer und Sensoren
olqs
ich hab seit gestern endlich alle Teile bekommen und meinen Desktop zusammengebaut.
Was ich natürlich nicht bedacht habe ist, dass die Temperatur Sensoren nicht automatisch erkannt werden können.
Das Board hat laut Schaltplan im Handbuch einen NCT6686D dafür drauf. Der sollte vom mpdul nct6687d unterstützt werden. Da gibts ein AUR dafür, also installiert und geladen nur werden jetzt ein paar unrealistische Daten angezeigt:
Code:
nct6686-isa-0a20
Adapter: ISA adapter
+12V:          -25.22 V  (min = -25.22 V, max = -25.22 V)
+5V:             0.00 V  (min =  +0.00 V, max =  +0.00 V)
+3.3V:           3.42 V  (min =  +0.00 V, max =  +3.42 V)
CPU Soc:         0.00 V  (min =  +0.00 V, max =  +0.00 V)
CPU Vcore:       0.00 V  (min =  +0.00 V, max =  +0.00 V)
CPU 1P8:         0.00 V  (min =  +0.00 V, max =  +0.00 V)
CPU VDDP:        0.00 V  (min =  +0.00 V, max =  +0.00 V)
DRAM:            0.00 V  (min =  +0.00 V, max =  +0.00 V)
Chipset:         0.00 V  (min =  +0.00 V, max =  +0.00 V)
CPU SA:          0.00 V  (min =  +0.00 V, max =  +0.00 V)
Voltage #2:      0.00 V  (min =  +0.00 V, max =  +0.00 V)
AVCC3:           0.00 V  (min =  +0.00 V, max =  +0.00 V)
AVSB:            3.39 V  (min =  +0.00 V, max =  +3.39 V)
VBat:            1.86 V  (min =  +0.00 V, max =  +1.86 V)
CPU Fan:        759 RPM  (min =  759 RPM, max =  813 RPM)
Pump Fan:         0 RPM  (min =    0 RPM, max =    0 RPM)
System Fan #1:    0 RPM  (min =    0 RPM, max =    0 RPM)
System Fan #2:    0 RPM  (min =    0 RPM, max =    0 RPM)
System Fan #3:    0 RPM  (min =    0 RPM, max =    0 RPM)
System Fan #4:    0 RPM  (min =    0 RPM, max =    0 RPM)
System Fan #5:    0 RPM  (min =    0 RPM, max =    0 RPM)
System Fan #6:    0 RPM  (min =    0 RPM, max =    0 RPM)
CPU:           +216.0°C  (low  = +216.0°C, high = +216.0°C)
System:         +35.5°C  (low  = +35.0°C, high = +35.5°C)
VRM MOS:        +33.0°C  (low  = +33.0°C, high = +33.0°C)
PCH:            +47.0°C  (low  = +47.0°C, high = +47.0°C)
CPU Socket:     +70.0°C  (low  = +69.0°C, high = +70.0°C)
PCIe x1:        +62.0°C  (low  = +62.0°C, high = +62.0°C)
M2_1:           +63.0°C  (low  = +63.0°C, high = +63.0°C)
pwm1:               44%
pwm2:               73%
pwm3:              128%
pwm4:               38%
pwm5:               38%
pwm6:               38%
pwm7:                0%  MANUAL CONTROL
pwm8:                0%  MANUAL CONTROL
CPU Temp von 216°C und +12V kann so nicht stimmen. Fan Speed passt aber.
Gibts da noch irgendeinen Trick, ein anderes Kernelmodul, oder muss ich einfach warten und hoffen?
Ach ja OS: CachyOS, aber ist nicht meine erste Linux Installation
Danke euch
Gruß T.
Erster Satz auf der Seite
Linux eignet sich nicht zum Spielen, es ist ein Betriebssystem für die Arbeit.
:what:
