#!/usr/bin/vmplayer
.encoding = "windows-1252"
# Filename: Linux64_FAH.vmx
# Generated 2009-10-29;06:06:21 by EasyVMX! 2.0 (beta)
EasyVMX!: Virtual Machine Creator
# This is a Workstation 6 config file
# It can be used with Player
config.version = "8"
virtualHW.version = "6"
# Selected operating system for your virtual machine
guestOS = "other26xlinux-64"
# displayName is your own name for the virtual machine
displayName = "Linux64_FAH_amd-main"
# These fields are free text description fields
annotation = "Linux64 FAH"
guestinfo.vmware.product.long = "Linux64 FAH"
guestinfo.vmware.product.url = "http://www.easyvmx.com/"
guestinfo.vmware.product.class = "virtual machine"
# Number of virtual CPUs. Your virtual machine will not
# work if this number is higher than the number of your physical CPUs
numvcpus = "4"
# Memory size and other memory settings
memsize = "1536"
MemAllowAutoScaleDown = "FALSE"
MemTrimRate = "-1"
# PowerOn/Off options
gui.powerOnAtStartup = "FALSE"
gui.fullScreenAtPowerOn = "FALSE"
gui.exitAtPowerOff = "FALSE"
# Unique ID for the virtual machine will be created
uuid.action = "create"
# Settings for VMware Tools
tools.remindInstall = "FALSE"
# Startup hints interfers with automatic startup of a virtual machine
# This setting has no effect in VMware Player
hints.hideAll = "TRUE"
# Enable time synchronization between computer
# and virtual machine
tools.syncTime = "TRUE"
# First serial port, physical COM1 is not available
# Optional second serial port, physical COM2 is not available
# First parallell port, physical LPT1 is not available
# Logging
# This config activates logging, and keeps last log
logging = "TRUE"
log.fileName = "Linux64_FAH.log"
log.append = "TRUE"
log.keepOld = "3"
# These settings decides interaction between your
# computer and the virtual machine
isolation.tools.hgfs.disable = "FALSE"
isolation.tools.dnd.disable = "FALSE"
isolation.tools.copy.enable = "TRUE"
isolation.tools.paste.enabled = "TRUE"
# Other default settings
svga.autodetect = "TRUE"
mks.keyboardFilter = "allow"
snapshot.action = "autoCommit"
# First network interface card
ethernet0.present = "TRUE"
ethernet0.virtualDev = "e1000"
ethernet0.connectionType = "nat"
ethernet0.addressType = "generated"
ethernet0.generatedAddressOffset = "0"
# Settings for physical floppy drive
# Settings for physical CDROM drive
ide1:0.present = "TRUE"
ide1:0.deviceType = "cdrom-raw"
ide1:0.startConnected = "TRUE"
ide1:0.fileName = "auto detect"
ide1:0.autodetect = "TRUE"
# First IDE disk, size 4Gb
ide0:0.present = "TRUE"
ide0:0.fileName = "Linux64_FAH.vmdk"
ide0:0.mode = "persistent"
ide0:0.startConnected = "TRUE"
ide0:0.writeThrough = "TRUE"
# Hardware clock to UTC
rtc.diffFromUTC = 0
extendedConfigFile = "Linux64_FAH.vmxf"
virtualHW.productCompatibility = "hosted"
uuid.action = "keep"
checkpoint.vmState = ""
ethernet0.generatedAddress = "00:0c:29:ca:ed:79"
uuid.location = "56 4d 55 01 8e 7a 33 8a-d3 48 de 8e 5b ca ed 79"
uuid.bios = "56 4d 55 01 8e 7a 33 8a-d3 48 de 8e 5b ca ed 79"
cleanShutdown = "TRUE"
replay.supported = "FALSE"
replay.filename = ""
ide0:0.redo = ""
ethernet0.pciSlotNumber = "16"
vmotion.checkpointFBSize = "16777216"
serial0.present = "FALSE"
serial1.present = "FALSE"
parallel0.present = "FALSE"
floppy0.present = "FALSE"
