OCZ kündigt neuen CPU-Kühler Vanquisher an
The OCZ Vanquisher aggressively cools your CPU thanks to a pure copper base plate and three copper heat pipes that rapidly transfer heat away from the processor up to the dense, aluminum fin array where the thermal load is quickly dissipated by the included 92mm fan. The efficient heatpipe design moves so much heat that the fin array is able to transfer up to 200 Watts. The Vanquisher also utilizes a unique low speed fan mounted with rubber connectors to effectively decrease vibration and noise, ensuring minimal distractions at your workstation.
The performance of OCZ Vanquisher is not compromised due to its compact size, states Jacky Huang, VP of Product Management, OCZ Technology. Instead, it reduces the CPU temperature more effectively than many larger coolers in the market. As a bonus, its compact form factor allows it to fit in even most crowded environments and cases.
The extremely compact and versatile OCZ Vanquisher CPU cooler is compatible with sockets AMD 754/939/AM2 and Intel 775. Because no motherboard back plate is required, the hassle-free Vanquisher is installed quickly and easily for consumers of all skill levels. With no need to remove your motherboard to install this cooler, the OCZ Vanquisher can get right to work cooling your CPU and enhancing your computing experience in seconds.
Light-weight and quiet, compact yet highly resourceful, the OCZ Vanquisher provides superior and reliable cooling with its state-of-the-art design for enthusiasts looking to upgrade for better performance and improved system stability.
- For Sockets AMD 754/939/AM2, Intel LGA775*
- Pure Copper base plate and 3 heat pipes for superior heat dissipation - Pure Aluminum fins for ultimate durability
- 1 year warranty
Fan Specs
- Rated Voltage: 12 V DC
- Fan Speed: 800-2000RPM
- Bearing type: Ceramic
Dimensions:
- Heatsink: (L)72 x (W)110 x (H)134mm
- Fan: (L)92 x (W) 92 x (H)25mm
Includes:
- 92mm Fan and rubber mounting clips
- Mounting Hardware for all above CPUs
- Thermal Compound
- 1 year warranty
Fan Specs
Dimensions:
Includes:
- Thermal Compound
.gif)
