AW: Diskette für BIOS zu klein, Alternativen?
Na warum denn so umständlich Mädels
Jedes Gigabunt Board hat im BIOS das Q-Flash Menü. Taste F12 im Bootscreen drücken.
Ich darf mal wieder das Handbuch zitieren, denn wer lesen kann, ist klar im Vorteil
Follow the steps below before using Q-Flash to update BIOS:
1. From GIGABYTE's website, download the latest compressed BIOS update file that matches your
motherboard model.
2. Extract the file and save the new BIOS file (e.g. 965GDS3.F1) to your floppy disk, USB flash drive,
or hard disk. Note: The USB flash drive or hard disk must use FAT32/16/12 file system.
3. Restart the system. During POST, press the End key to enter Q-Flash. Note: You can access
Q-Flash by either pressing the End key during POST or the F8 key in BIOS Setup. However, if the
BIOS update file is saved to a hard drive in RAID/AHCI mode or a hard drive attached to an
independent IDE/SATA controller, use the End key during POST to access Q-Flash.
Step 1:
a. In the Q-Flash menu, use the UP or DOWN ARROW key to select Update BIOS from Drive and
press ENTER.
b. Select the floppy drive or hard drive where the BIOS file is saved, such as "Floppy A" and
press ENTER.
c. Select the BIOS file and press ENTER.
Make sure again the BIOS file matches your motherboard model.
Step 2: The process of system reading the BIOS file from the floppy disk is displayed on the screen.
When the message "Are you sure to update BIOS?" appears, press ENTER. The BIOS update
will begin and the current process will be displayed.
1. Do not turn off or restart the system when the system is reading/updating the BIOS.
2. Do not remove the floppy disk or hard drive/USB drive when the system is updating the BIOS.
Step 3: When the update process is complete, press any key to return to the Q-Flash main menu.
Step 4: Press ESC and then ENTER to exit Q-Flash and the system will restart. As the system reboots,
you will see the new BIOS version during POST.
Step 5: As the system reboots, press DELETE to enter BIOS Setup. Select Load Optimized Defaults
and press ENTER to load BIOS defaults. System will re-detect all peripherals devices
after BIOS update, so we recommend that you reload BIOS defaults.
Warum ist nur jeder zu faul das Handbuch zu lesen? Bei Gigabyte ist, es je nach Modell, sogar in deutsch, für die jenigen die der englischen Sprache nicht mächtig sind.
Das Flashen des BIOS in Windows is a big nono ! Würde ich nur bei Dual Bios empfehlen, aber das Thema haben wir hier schon gründlich zerkaut.
