[Sammelthread] Asus Maximus II Formula (Intel P45)
devic
  • Spezifikationen
  • Bilder
  • BIOS
  • Wichtige Informationen
  • Wichtige Links / Downloads
CPU:
  • Intel Socket 775 Processors for Intel® Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium® dual-core/Celeron® dual-core /Celeron® Processors
  • Support Intel® next generation 45nm Multi-Core CPU
  • Compatible with Intel® 06/05B/05A processors
Chipsatz:
  • Intel P45 Chipsatz
  • Intel ICH10R Southbridge
Speicher:
  • 4 x240-pin DIMM, Max. 16 GB, DDR2 1200/1066/800/667 Non-ECC,Un-buffered Memory
  • Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lidts).
  • When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
QVL-Liste siehe Wichtige Links / Downloads
Erweiterungs-Slots:
  • 2 x PCIe 2.0 x16 (single max @16,dual @ x8 speed)
  • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 2 x PCI 2.2
Multi-GPU Unterstützung:
  • Unterstützt ATI CrossFireX™
Storage:
  • 6 xSATA 3 Gb/s ports Intel Matrix Storage Technology supports Support RAID 0,1,5,10 Marvell® 88SE6121 controller
  • 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
  • 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
  • Silicon Image Sil5723
  • 2 x SATA 3.0 Gb/s ports
  • Supports RAID 0, 1
Audio:
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - Creative X-Fi capability
    - X-Fi interface
  • Coaxial/Optical S/PDIF out ports
LAN:
  • Dual Gigabit LAN, both featuring AI NET2
  • Support Teaming Technology
Interne IO-Anschlüsse:
  • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector for two devices
  • 6 x SATA connectors (Blue)
  • 2 x Speeding HDD connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 3 x thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x Chassis Intrusion connector
  • 24-pin ATX Power connector
  • 8-pin ATX 12V Power connector
  • 1 x En/Dis-able Clr CMOS
  • 1 x LCD Poster connector
  • 1 x ROG connector
  • 1 x Power-on switch
  • 1 x Reset switch
  • System panel connector
externe IO-Anschlüsse:
  • 1 x PS/2 Keyboard port(purple)
  • 1 x eSATA port
  • 2 x LAN (RJ45) ports
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Lieferumfang:
  • LCD Poster
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • Q-Shield
  • Cable Ties
  • User's manual
Quelle = OCXtreme
http://img259.imageshack.us/img259/3918/img1836bs5.th.jpg http://img261.imageshack.us/img261/347/img1837rl1.th.jpg http://img204.imageshack.us/img204/9984/img1853ia5.th.jpg http://img443.imageshack.us/img443/1432/img1839ol3.th.jpg http://img409.imageshack.us/img409/8704/img1840ys9.th.jpg
http://img507.imageshack.us/img507/8302/img1841bt6.th.jpg http://img165.imageshack.us/img165/8671/img1842qr1.th.jpg http://img444.imageshack.us/img444/2104/img1843ko4.th.jpg http://img409.imageshack.us/img409/1460/img1844io6.th.jpg http://img165.imageshack.us/img165/5048/img1845nl6.th.jpg
http://img165.imageshack.us/img165/3135/img1846fp4.th.jpg http://img521.imageshack.us/img521/953/img1847hm1.th.jpg http://img357.imageshack.us/img357/5108/img1848qz7.th.jpg http://img210.imageshack.us/img210/5352/img1849yf9.th.jpg http://img296.imageshack.us/img296/5915/img1850jk0.th.jpg
http://img444.imageshack.us/img444/9220/img1851iq6.th.jpg http://img507.imageshack.us/img507/1668/img1852us8.th.jpg http://img505.imageshack.us/img505/7494/img1856jh6.th.jpg http://img444.imageshack.us/img444/5251/img1854pj2.th.jpg http://img402.imageshack.us/img402/6462/img1855sa9.th.jpg
Quelle: XtremeSystems.org
49758d1228683575-sammelthread-asus-maximus-ii-formula-intel-p45-wichtige-informationen.png
Kompatible Kühler:
  • Alpenfön Groß Clock'ner (nur mit leichtem Verbiegen der Lamellen!)
  • Arctic Freezer 7 Pro
  • Asus Silent Night 1+2
  • Asus Triton 79
  • Coolermaster Hyper 212
  • Noctua NH-U-12P
  • Scythe Mugen / Infinity
  • Thermalright IFX-14 (HR-10 passt nur mit Bearbeitung)
  • Thermalright Ultra 120 eXtreme / True Black
  • Thermaltake Sonic Tower
  • Xigmatek HDT-S1283 / Red Scorpion
  • Zalman CNPS 9500AT
  • ZHEROtherm Nirvana NV 120
Wobei hier zu sagen ist, dass man von wenigen inkompatiblem Kühlern ausgeht, weil das Mainboard durch die flache Heatpipe sehr Kühler-freundlich ausgelegt ist
__________
Kompatibler RAM:
  • 2x 1GB A-DATA Vitesta Extreme DDR2-800
  • 2x 1GB Corsair XMS2 DHX DDR2-800
  • 2x 1GB Aeneon XTune DDR2-1066
  • 2x 1GB Patriot Viper DDR2-1150
  • 2x 1GB CompuStocx Diablo DDR2-1200
  • 2x 1GB OCZ Flex XLC DDR2-1200
  • 4x 1GB Crucial Ballistix (Tracer) DDR2-1066
  • 4x 1GB Corsair Dominator DDR2-1066
  • 2x 2GB Corsair DHX DDR2-800
  • 2x 2GB OCZ XTC Platinum DDR2-1000
  • 2x 2GB Apogee GT DDR2-1066
  • 2x 2GB Transcend aXeram DDR2-1066
  • 2x 2GB Corsair Dominator DDR2-1066
  • 2x 2GB G.Skill F2 4GBPK DDR2-1066
  • 2x 2GB G.Skill F2 4GBPI DDR2-1066
  • 2x 2GB G.Skill F2-4GBPI DDR2-1100
  • 2x 2GB Mushkin XP2 DDR2-1100
  • 2x 2GB OCZ Flex II DDR2-1150
  • 2x 2GB Chaintech Apogee GT DDR2-1150
  • 4x 2GB Transcend JetRam DDR2-800
  • 4x 2GB Corsair Dominator DDR2-1066
  • 4x 2GB OCZ Platinum XTC DDR2-1066
__________
Die GTL-Einstellung:
Die GTL ist ein Teiler. Sie ergibt mit der VTT multipliziert einen Wert in mV. Bei den meisten Board benutzt man den Teiler um auf einen höheren/niedrigeren (eben für die CPU perfekte) Endspannung zu kommen. Beim Maximus II Formula wird dieser Teiler jedoch gefixt und dafür von der Endspannung in mV abgezogen. Das hat den Vorteil, dass sich die Endspannung bei gleicheingestellter GTL nicht durch die variable VTT ändert.
Beispiel mit Asus P5Q Deluxe und vielen anderen Boards:
VTT x GTL = mV
1,1V x 0,63V = 693mV
Beispiel mit Asus Maximus II Formula:
VTT x fixed GTL = mV - mV
1,1V x 0,677 = 744,7mV - 50mV
Beide Beispiele kommen auf etwa das gleiche raus ;)
Dickgedruckt = Jeweils im BIOS einstellbare Werte
__________
Northbridge Temperaturproblem beheben:
Um die zu hohen Temperaturen der Northbridge zu senken, muss der Anpressdruck des Kühlsystems verstärkt werden. Dazu muss das Board ausgebaut und umgedreht werden. Daraufhin werden unter die Schrauben, die die Heatpipekühlung auf der Northbridge halten einfach zwei Unterlegscheiben (0,5 - 1mm) gelegt. Das erhöht den Anpressdruck und senkt gleichzeitig die Temperaturen der Northbridge.
__________
Messpunkte:
Anhang anzeigen 73111 Anhang anzeigen 73112 Anhang anzeigen 73113
Quelle: Awardfabrik.de (@arne)
__________
49759d1228683575-sammelthread-asus-maximus-ii-formula-intel-p45-wichtige-links-downloads.png
Fransen
Bin gerade auch meinen Umzug vom AMD auf Intel am Planen;)
Zur Auswahl stehen bei mir das Maximus Formula und das P5Q-Deluxe.
Als Prozi. wird mit Sicherheit ein E8400 das Rennen vor dem Xeon machen:devil:
xTc
Volt-Modder(in)
Ich spiele gerade auch mit dem Gedanken von meinem Rampage Forumla (X48) auf ein P45 Board um zusteigen.
Bin mir nur noch nicht sicher, ob es ein P5Q Deluxe oder ein P5Q Premium werden soll.
DanielX
Wie geil kann mir mal jemand sagen warum in der Miniaturansicht die Farben fälsch sind, LOL.^^
Und bin ich der einzige der das findet oder ist das Board für das was es kann, ein wenig winzig ??
Fransen
Hast recht bei mir sind sie auch iwie komisch;)
Aus rot ist blau geworden, aus gelb,grün und aus blau braun oder so:hmm:
Robär
Hab es mir am Mittwoch bestellt und ich warte und warte...Will das endlich haben! Mein jetziges nervt mich ³.
TE
TE
devic
devic
Ich wohn um die Ecke :) 4km :)
Ich kenn dich doch ausm Forumdeluxx Ace oder?
Zu den verfälschten Farben:
Weil ich zur der Zeit in der ich den Sammelthread geschrieben hatte nicht mit meinem eigenen PC arbeiten konnte, ist mir sicherlich mit GIMP bei der Verkleinerung der Bilder ein Fehler unterlaufen. Vielleicht einen Farbkanal deaktiviert oder so, kA.
Der Sammelthread läuft übrigens auch im Forumdeluxx...
Robär
So wie hier, bin da aber erst nen paar tage und nicht sehr aktiv.
@Topic
Hat jem. ne Peilung wann ich mein Board bekommen könnte? Bestellt bei bestseller-computer am Mittwoch.
Robär
Ich habe meins letzte Woche DI bei Bestseller-Computer bestellt. Heute wurde mir mitgeteilt das es am 11.07 !!! da sein soll. NA GOIL.
Ace
habs erst mal normal gemacht (wie man halt Raid erstellt) erst mal Testen wie das Board ist dann sehe ich mal weiter
TE
TE
devic
devic
Das Maximus II Formula passt doch garnicht in dein System... Hab eben zum ersten Mal deni Sysprofile angeguckt. Echt hammer!
